Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 133
    May 2013
    #81
    Quote Originally Posted by jmpet626 View Post
    Ang mahal sir makaka bili ka na ng bnew na rotors niyan with repair kit na din.
    para saan yun repair kit?
    Aug 2014
    #82
    Mga bro any servitek shops sa qc are?
    Dec 2004
    #83
    Quote Originally Posted by shaq1968 View Post
    Near the corner of Araneta and Magsaysay (actually the street before which is Palansa). Malapit sa SM Sta Mesa
    Oct 2015
    #84
    mga bossing...
    ask ko lng ano ang maririnig mo or mararamdaman pag pudpod na ang brakepad...salamat po.
    Jun 2007
    #85
    may parang nagkikiskisang bakal
    #86
    Quote Originally Posted by burstcruiser View Post
    mga bossing...
    Metallic screeching sound lalo nag pag nag-brake ka.
    #87
    mga bossing...
    Oct 2015
    #88
    Questions:
    When should i add the break fluid? When its on low level only or it is possible to add in the medium level...?
    difference of DOT 3 & DOT 4?
    Is it possible to mixed them? Because i forgot to ask the mechanic which brake fluid did he add durings pms..
    Edit:
    The brand of brake fluid is not stated on the manual. So, in this case, what brand can you recommend for me to use?
    Thanks
    #89
    Quote Originally Posted by khenma0928 View Post
    Questions:
    Edit:
    Thanks
    i just keep the fluid level between the two lines.
    the manual should indicate the type of fluid, po.
    Jun 2008
    #90
    Quote Originally Posted by thephantom View Post
    Na bayaran ko na e. So warning nlng sainyo. Almazan car shop yung pangalan sa bf paranaque. Iwasan niyo na yung car shop na yun. Any suggestions for a good car shop in paranaque? Bf area sana.
    Huwaaah!!! Ang lakas tumaga, sobra pa sa rapide. Tandaan ko ang shop na yan. Thks sa info sir.
    #91
    Questions:
    Edit:
    Thanks
    Brake fluid absorbs moisture so it's good to replace this from time to time. Most manuals recommend every 40,000kms but in my case i do this every 20,000kms. Mura lang naman.
    Difference between DOT3 and DOT4 is their heat range; DOT4 can take higher tempatures and is used mostly for performance purposes suchas track days or those who do a lot of hard mountain driving. In most cases, DOT3 is fine. The only time i have encountered oveheating brake fluid was on the track. DOT4 is more expensive and i think they are more hygroscopic.
    Oct 2015
    #92
    DOT 3 OR.4 lng po ang nkalagay... What brand do u recommend?
    #93
    Any off-the-shelf brand is fine (Prestone, Bendix, etc.). I usually buy the Bendix fluid. What is important is you dont mix DOT3 and DOT4.
    Oct 2015
    #94
    May difference b sa color ang dot 3 and dot 4?
    Aug 2014
    #95
    Need your opinion brothers. My car is nissan sentra 2007 gx model. I have to replace my break pads to original kasi yung bendix na gamit ko hindi maganda for my tires. Then my wheels need bearing replacement I got this quote from a mechanic that works for nissan. All original parts daw toh. Ask ko lng kung tama lng ba yung price. Note lng i hhome service niya yung repair
    "sir gd eve ung wheelbearing sa harap 2,742 po ang isa *2 , ung breakpads po 3,748,ung caliperpin with bushing 839 po ang isa *4 ung wheelbearing assembly 7,185 ang labor ko po 2,500 ang total po lhat 22,273"
    #96
    wow! hanap ka iba sir
    #97
    bring it to banawe or pedro gil, po. i do this, and i get off-the-shelf parts, as recommended by the mekaniko there.
    you can save about 50%.
    and casa does not hold the patent to parts quality.
    just stay away from the "very cheap" parts.. you know.. "the parts bayan sellers use"..
    May 2009
    #98
    ginto ang pyesang casa. pero may makukuha ka pang magandang brands comparable to oem quality sa mas mababang presyo.
    OT.....grinasahan ko yung caliper pins pati na rin yung pin boots ng sasakyan ko gamit silicone grease. nilinis din syempre mga brake pads at discs. kaso after a few miles e may squeaking sounds kapag nagtuturn to the left at speeds higher than 20 kmh. hmmmmm.
    Mar 2005
    #99
    Quote Originally Posted by miked View Post
    AFAIK di pwede silocone grease as brake/pin grease. Gamit ko Wurth pad grease 100 pesos per sachet sa Auto Supply. Kahit di ka umaapak ng brakes mga squeaking sounds?
    Jun 2005
    #100
    Copper grease dapat
Brake Maintenance
