Page 62 of 76 FirstFirst ... 125258596061626364656672 ... LastLast
Results 1,221 to 1,240 of 1510
    Oct 2015
    #1221
    Pag 140 na kasi parang tumatalbog na. So ma leless yun pag malapad ang gulong sir,
    Mar 2004
    #1222
    Wider tires will also consume more fuel.
    #1223
    I actually observed this with my car. Stock was 175/70/14 (dia. 602 mm), upped to 185/70/14 (dia. 616 mm). FC worsened initially. Still w/in the 3% advised. Used to ave. 5.3-5.5 L/100, immediately down to 5.7-6. I think it's the effort to roll the bigger tire from a stop.
    Oct 2015
    #1224
    I see. Thats the effect of bigger tire. Maybe dahil mas mabigat? Or mas mahirap e roll?
    Pero more grip on the road. Means more safe?
    Mar 2004
    #1225
    Wider tires will be able to provide more grip when cornering and stopping (assuming the brake system can handle it).
    Jun 2006
    #1226
    My stock rims, 17x7.5J ( I have no idea what 7.5J means, is it 7.5 inches??)
    currently on stock rubber, 205/50/17.
    How much wider can I widen the rubber (if that's possible) or do I have to upgrade to wider rims too just for the little widening?
    Currently very happy with my Continental CP2E. What would be better but not significantly more expensive? I like the grip of the Continental especially in wet but the noise is just bothering me esp on imperfect/unpaved roads. On fresh, properly done tarmac though, it's very quiet.
    Apr 2013
    #1227
    7.5j is the width of the rim. You can go 215/45 if you want but for me the stock tyre size is enough. Going wider would risk you to have a rubbing problem especially if you lower the car.
    #1228
    Quote Originally Posted by Horsepower View Post
    For 17x7.5, you can go with as wide as 235mm. To keep about the same wheel & tire dimensions as your stock setup, you can try 225/45/17 or 235/45/17. I suggest 225/45/17 as going for 235/45/17 may cause some rubbing due to the offset of the wheels. If you want to lower the car, go with a smaller tire like the 215/45/17. I used to run 225/45/17 on 17x7J rims (42 offset, I think) with my old 6th gen Accord on stock suspension height with no rubbing.
    For the tires, you may want to try Bridgestone's GR series (GR90 current model). They offer good overall performance for a touring tire - decent wet & dry grip, not noisy at triple digit speeds. For sports tires like Potenza, they are noisier but offer better grip.
    Jun 2006
    #1229
    Thanks a lot sir Egan101!
    Nov 2015
    #1230
    Mga sir's sino po gumagamit ng black lion tire sainyo?need you insights po salamat po!
    Oct 2015
    #1231
    Meaning pla ung may alloy wheels na 18' ay matagtag?
    Oct 2015
    #1232
    Ang alam ko sir matagtag yan kasi manipis ang gulong. Less ang bouns,
    Aug 2013
    #1233
    Quote Originally Posted by khenma0928 View Post
    naka 18s ako bro, hindi naman matagtag.
    from 205/65r15 to 235/50r18, same lang ng ride comfort sa lubak at uneven road surface pero mas smooth siya sa highway kesa sa stock tire and wheel specs.
    at higit sa lahat, nawala yung pagka bouncy feel ng innova. mas naging compose/calm yung movements niya kesa sa stock tires.
    Innova 3rd gen nakakabit.
    Jan 2014
    #1234
    i think it should come out cheaper after discount.
    i got the 265/65/r17 A/T tires for the fortuner few months back, was quoted 9+k each. so i paid 28k with the promo for 4 tires including mounting, balancing (except wheel weights), wheel alignment, and nitro.
    same size of bridgestones nasa 11k yata each if im not mistaken. so far happy with the federals.
    Bro kamusta Yung federal tire? Maganda ba?
    Mar 2016
    #1235
    which is better on my list for 195/50/15
    toyo drb
    toyo proxes t1r
    federal evo 595
    or any other brands suggested.
    im confused what tire will i get..i need tires na hindi mauugong at the same time comfortable pa din ride.thank you so much.
    #1236
    [QUOTE=macdaddy;2703982]which is better on my list for 195/50/15
    toyo drb
    toyo proxes t1r
    federal evo 595
    im confused what tire will i get..i need tires na hindi mauugong at the same time comfortable pa din ride.thank you so much.[
    Bro, why not add GT Champiro SX2 to your shortlist?
    Sep 2004
    #1237
    Quote Originally Posted by macdaddy View Post
    toyo drb
    toyo proxes t1r
    federal evo 595
    tahimik and comfortable para sakin yung Bridgestone Turanza, used 2 sets of it on my old sedan for the past years.
    ^ ang ayoko sa bridgestone turanza ay walang rim protector
    at the beginning of the year i finally replaced those turanzas w/ neuton nt 5000s on my car and i'm pleasantly surprised by its performance considering it's a budget tire
    Jan 2016
    #1239
    mahal din ang bridgestone turanza, they go for more than 2x the price of yokohamas
    Mar 2016
    #1240
    [QUOTE=bloowolf;2703985]
    toyo drb
    toyo proxes t1r
    federal evo 595
    good for daily driven car yung gt champiro sx2? ano po threadwear nya? ok naman sidewall sir?
The Best Brand of Tires
