Results 1,221 to 1,230 of 1510
- Oct 2015
- 922
November 12th, 2015 12:46 AM #1221Pag 140 na kasi parang tumatalbog na. So ma leless yun pag malapad ang gulong sir,
November 12th, 2015 08:43 AM #1223
I actually observed this with my car. Stock was 175/70/14 (dia. 602 mm), upped to 185/70/14 (dia. 616 mm). FC worsened initially. Still w/in the 3% advised. Used to ave. 5.3-5.5 L/100, immediately down to 5.7-6. I think it's the effort to roll the bigger tire from a stop.
- Oct 2015
- 922
November 12th, 2015 09:38 AM #1224I see. Thats the effect of bigger tire. Maybe dahil mas mabigat? Or mas mahirap e roll?
Pero more grip on the road. Means more safe?
November 12th, 2015 02:33 PM #1225
Wider tires will be able to provide more grip when cornering and stopping (assuming the brake system can handle it).
November 12th, 2015 03:36 PM #1226
My stock rims, 17x7.5J ( I have no idea what 7.5J means, is it 7.5 inches??)
currently on stock rubber, 205/50/17.
How much wider can I widen the rubber (if that's possible) or do I have to upgrade to wider rims too just for the little widening?
Currently very happy with my Continental CP2E. What would be better but not significantly more expensive? I like the grip of the Continental especially in wet but the noise is just bothering me esp on imperfect/unpaved roads. On fresh, properly done tarmac though, it's very quiet.
- Apr 2013
- 236
November 12th, 2015 04:18 PM #12277.5j is the width of the rim. You can go 215/45 if you want but for me the stock tyre size is enough. Going wider would risk you to have a rubbing problem especially if you lower the car.
November 12th, 2015 04:20 PM #1228
For 17x7.5, you can go with as wide as 235mm. To keep about the same wheel & tire dimensions as your stock setup, you can try 225/45/17 or 235/45/17. I suggest 225/45/17 as going for 235/45/17 may cause some rubbing due to the offset of the wheels. If you want to lower the car, go with a smaller tire like the 215/45/17. I used to run 225/45/17 on 17x7J rims (42 offset, I think) with my old 6th gen Accord on stock suspension height with no rubbing.
For the tires, you may want to try Bridgestone's GR series (GR90 current model). They offer good overall performance for a touring tire - decent wet & dry grip, not noisy at triple digit speeds. For sports tires like Potenza, they are noisier but offer better grip.Last edited by Egan101; November 12th, 2015 at 04:25 PM.
- Nov 2015
- 4
November 12th, 2015 10:02 PM #1230Mga sir's sino po gumagamit ng black lion tire sainyo?need you insights po salamat po!
Xiaomi E-Car
