Results 41 to 48 of 48
- Mar 2010
- 2,273
February 12th, 2021 03:25 PM #41Launch X431 CRP129E OBD2 Scanner Engine ABS SRS Transmission Diagnostic-Tool Brake/Oil /SAS /ETS/TPMS reset
Top 7 reason to choose CRP129E
1. CRP129E is an upgraded version of CRP129 and Creader VIII , Support more protocols , including:OBD2 , EOBD, JOBD, KOBD ( old car and new car)
2. Android 7.0 Touch Screen , Easy to operate
3. Support more car brand , 57 kind of global car brand
4. 5 Reset Service : EPB reset , Oil reset , SAS reset ,ETS reset TPMS reset
5. Fast VIN autodetect, Lifetime free update via wifi
6. Print : print diagnostic report via email share
7. Multi-language :English, Spanish, French, German, Italian, Russian, Japanese, Korean, Portuguese
Introduction:
Creader Professional 129E is an evolutionary smart solution for passenger car diagnosis. It inherits from LAUNCHrsquos advanced diagnosing technology and is characterized by covering a wide range of vehicles, featuring powerful functions, and providing precise test result.
CRP129E support muiti-protocols test for a complete diagnosis.CRP129E also supports the system diagnosis of Engine , ABS Airbag, SRS Airbag and Transmission system
Engine/ABS/SRS Airbag/Transmission Diagnosis
Diagnostic Engine System:
The diagnostic tool can help detect the engine ignition, fuel injection, air and fuel ratio, and exhaust emission conditions in Engine system to enhance vehicle performance, save energy and reduce exhaust emission.
It makes great sense in the safe driving when your car is slipping or difficult to shift. This diagnostic scanner can figure the problems out via reading codes in the Transmission system, or check the health status via live data viewing.
Diagnosing an ABS problem should always start with a visual inspection of all brake components, next you will need to retrieve ABS codes to tell you where the problem is, and this is what this scanner does for you.
SRS, safety restraint system, is made up of impact sensors, a control module, and the airbags themselves, and this diagnostic device can detect every electronic parameter to check its health status.
Diagnostic SRS Airbag System:
Diagnostic ABS System:
Diagnostic Transmission:
Launch CRP129E Processional special function:
Oil Service Light Reset
Allows you to perform reset maintenance mileage and data intervals for a new calculation of Engine Oil Life system once changed the oil.
It is important in the maintenance of electronic braking systemrsquos safety and efficiency when replace brake pad or motor
Helps clear the fault steering angle sensor memories and plays an important role in the steering angle sensor calibration
Vehicle's throttle position system sensor connected to the butterfly spindle and is primarily used to monitor the throttle position within an inner combustion engine. Due to its location, the throttle position sensor is able to effectively observe where the throttle butterfly valve is positioned.
Makes sense in displaying sensor IDs from the vehicle's ECU, inputting TPMS sensor replacement IDs and testing sensors.
Note : These special function NOT for all car models, if you are confused, Please send your car brand, model and release year to me, I will check for you.
Tire pressture system reset
Electronic throttle position reset
SAS Steering Angel Sensor Reset
EPB Electronic Park Brake Reset
Product features
Function shows
Easy to operate & convenience for using
Specification:
Screen: 5inch Touch Screen
RAM: 1G
ROM: 8GB
Battery: 4000mAh rechargeable Li-battery
OBD II input voltage range: 9~18V
Charging via: DC 5V charging cable or Diagnostic cable through connection to vehiclersquos DLC
Dimension: 228mm x 125mm x 34.5mm
Working temperature: -10 to 50degC (14 to 122 Fdeg)
Storage temperature: -20 to 70degC (-4 to 158 Fdeg)
Packing List :
1. Creader Professional 129E handset
2. OBD II diagnostic cable
3. DC 5V charging cable
4. User manual
5. Carrying bag
captcha | lazadacom
Tool Test: Launch CRP129E Multi Vehicle Tool Honda Toyota Kia Ford GM - YouTube
- Mar 2010
- 2,273
February 12th, 2021 08:23 PM #42Eto bro from Lazada
February 12th, 2021 08:30 PM #43
February 27th, 2021 07:32 PM #45
Replaced sensors today, ABS warning light turned off after switching on.
- Jan 2008
- 4,726
March 1st, 2021 04:32 PM #46nice to see its all sorted out... anyway, did you check what could be the cause of the fault? are there cracks in the housing?
March 1st, 2021 04:48 PM #47
March 7th, 2021 07:40 AM #48
Best scanners for Kia Vehicles. The Bluedriver Pro is the only one available in Lazada
How to Pick an OBD2 Scanner for KIA Vehicles (22 edition)
Sent from my iPad using TapatalkLast edited by bloowolf; March 7th, 2021 at 07:47 AM.
Because pinoy mentality. Not surprising.
