So I finally was able to get the car scanned in Kia & the fault was the bearing sensor. That is the cap where the sensor plug attaches. Unfortunately, the part is not available at Kia but, Hyundai has it & I just have to wait for it.
yan maganda sa hyundai and kia, kahit papaano di ganun kahirap kumuha ng parts
btw bro ito ba yan?
Genuine Kia Rear Bearing Sensor 52751-2B1 | eBay
Oo, yan yun. Parang cap na may sensor sya ng bearing. Iba lang part number nito. Ang mahal lang ng parts ng Kia. P2,700 sa Kia, P1,500 sa Hyundai. Ang scanner nila may proprietary software connected to Kia online. Kaya siguro sabi, maski sa international forums, most scanners cannot pull the fault codes of Kia/Hyundai. Sabi rin in parts guy ng Hyundai, ang electronics hindi masasabi kung bibigay. Pinabili lang nya ako ng dalawa kasi pair daw kailangan pag palit. Ok na rin, basta meron.
Hindi ko lang alam kung KIA hawak din ng Olympia araneta, free doon ang scan sa mga suki.
Mayrun ako OBD2 scanner sa bahay pero wala ABS at seatbelt module
iniisip ko bili nalang obd to usb, then bayad nalang ng paid app for scanning srs, abs etc
pwede pa pang tune (at your own risk)
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
Mayroon kayang scanner sa Speedyfix, Drive+ or Titan Works? Puwede sila tawagan.
Nakakapagtaka ng Bridgestone Alabang sa Commerce Center kung bakit cheap scanner nila.
Pag dumating na yung bearing sensor, siguro mas mabuti kung sa Kia ko na rin ipakabit no? Kasi idedelete nila yung fault code. Baka kung sa Hyundai, hindi ma delete yung FC babalik ulit ako ng Kia.
Nag ilaw din abs icon ng sasakyan ko recently dahil napatid iyong wire niya. Had to call on my electrician because i was scared to diy it. It turns out napaka-simple pala gawin.
Nung nayari na, Hindi na kinailangan i-reset. Pina-andar ko lang ayuz na. [emoji4]
Replaced sensors today, ABS warning light turned off after switching on.
nice to see its all sorted out... anyway, did you check what could be the cause of the fault? are there cracks in the housing?
Best scanners for Kia Vehicles. The Bluedriver Pro is the only one available in Lazada
How to Pick an OBD2 Scanner for KIA Vehicles (22 edition)
