Page 318 of 341 FirstFirst ... 218268308314315316317318319320321322328 ... LastLast
Results 3,171 to 3,180 of 3407
    May 2018
    #3171
    You'll be fine. Just don't use tap next time. Best to keep a bottle of OE coolant or distilled water ( Wilkins or Absolute, not the vodka[emoji4]) for top up.
    I would never let the dealership top coolant or windshield fluid up....DIY it. I've seen dealerships add tap countless times.[emoji20]
    Haha.. noted on the Absolut Vodka Sir Travajante..[emoji1]
    Thanks po sa reply sir.. worried lang talaga ako lalo na't first time to own.. I read na it will cause rust and corrosion.
    I am thinking pa naman of going to MI on monday for a coolant flush. [emoji28]
    #3172
    Quote Originally Posted by tsik_r2d2 View Post
    Anytime, sir! I'm a bit OC, too. Tap has minerals that could cake w/ heat & time.
    I'm guessing you dint top up much. Don't you lose sleep over it.[emoji4]
    May 2018
    #3173
    To be honest sir mga 1L nalagay ko. [emoji28]
    Planning of buying a concentrated coolant para at least maneutralize ko. May advise po ba kayo na brand? Non turbo po ako.
    Appreciate your help Sir Trav!
    #3174
    Grab what Subaru puts for the next top up. Note that different coolant brands come in different colors.
    Mar 2004
    #3175
    Be careful, use ONLY Subaru Long Life Coolant ... There are alternatives but you have to be well informed about different types of coolants and their composition ... Incompatible coolant type MIGHT damage some metals in the engine ...
    Dec 2014
    #3176
    is there any way na mapapalit ang suspension ng forester with a suspension ng mga fortuner, montero type?
    #3177
    Quote Originally Posted by Richard Yap View Post
    The Forester is built on a unibody frame like a car unlike those PPVs which are built on a ladder frame like a pickup. The suspension setup is different between them.
    You can stiffen or raise the suspension of a Forester with the proper use of springs and shocks or coilovers. Besides, why would you make the Forester ride like a PPV? One of the great advantages of CUVs is how it drives compared to pickup-platform vehicles and how its suspension is tuned makes that difference.
    Dec 2014
    #3178
    mas type ko kasi yung ppv na suspension yung tipong rough road di mo mafefeel
    #3179
    The Forester has good ground clearance, as good as most PPVs. If you want to make the Forester be much better off-road, then you can upgrade the shocks and springs, lift the body a bit, and change to off-road tires.
    It will still handle better on twists and turns compared to those ladder frame vehicles.
    Dec 2014
    #3180
    if ever anong marerecommend mo na shop to do this? and how much would it cost?
Subaru Forester
