Results 141 to 150 of 159
- May 2006
- 1,668
March 10th, 2019 09:34 PM #141
March 11th, 2019 11:09 AM #142
Will test driving vehicles tell one how reliable they are? ...
Test driven ...
March 11th, 2019 11:13 AM #143
- Feb 2019
- 3
April 9th, 2019 08:35 AM #144Any wrx 2014 and above cvt owners here? Any known issues?
April 9th, 2019 12:32 PM #145
If properly maintained, there would be no issues. The WRX and XT uses the same engine and tranny with differences in tuning only.
If the car is regularly used, the previous owner may have changed the CVT fluid, front suspension bushings, brake pads, and tires. Unless of course, the car was sparingly used (garage queen). Check the tires for the manufacture date. You need to change tires if they are more than 5 years old already.
- Feb 2019
- 3
April 10th, 2019 07:43 PM #146
April 10th, 2019 07:50 PM #147
- Jun 2016
- 2
January 22nd, 2024 08:56 PM #148
January 23rd, 2024 09:10 AM #149
Yes, their bushings are not that good. I had to change mine twice before it reached 40k kms. Then, I switched to aftermarket bushings. Ran it for 35k kms so far. No problems so far.
Sent from my SM-T970 using Tsikot Forums mobile app
- Jan 2007
- 2,234
January 23rd, 2024 10:46 AM #150'07 WRX
Big turbo, exhaust, tune
68k kms
replaced power steering pump at 40k
major work at 50k kms/10 years old:
replaced radiator (started leaking at the plastic end tanks), did thermostat and water pump at the same time to be safe
also did ball joints and tie rod ends
replaced shocks and top-mounts (fitted coil-overs) at 65k kms
recharged a/c at 68k kms. o-rings needed replacement, but everything else (evaporator, etc) was intact.
planning on doing timing belt and tensioner at 70k. already have the parts.
high idle RPM at engine start
