Page 38 of 60 FirstFirst ... 2834353637383940414248 ... LastLast
Results 741 to 760 of 1187
    Mar 2004
    #741
    They key is for backup in case remote stops working (drained battery).
    thanks walter.
    Mar 2004
    #742
    is there anyone experiencing vibration on cold start from the engine? parang shudder. goes down when rpm goes down too. when engine is warm or hot wala naman.
    Jan 2014
    #743
    Quote Originally Posted by baker123 View Post
    Yes, normal yun as per M.I. Advised. Cold start may vibration and better Antayin mo mawala yung icon na blue "it means" Malamig pa si boxer engine bago ka mag shift to D . Haha
    Mar 2004
    #744
    Quote Originally Posted by K1elers View Post
    thanks k1elers. first time to experience it in a subaru. got worried that it could be a problem.
    #745
    Experienced it also sa showroom unit (forester xt) when started up.
    Jan 2014
    #746
    Quote Originally Posted by istan View Post
    Same here, so tinanong ko na bat ganon and bago kami mag test drive ng forester search/check muna ng reviews from other forums. So far sulit ang Subaru and boxer engine tipid siya Dahil sa new tranny lineartronic. Our first Subaru car, though under observation pa din kasi Hindi pa nakaka abot ng 1600k.
    Dec 2013
    #747
    hi guys!
    I've been driving my forester xt for 2 weeks already.
    earlier today i checked on the hood and noticed that the coolant level is above the LOW level.
    i didnt check if that was the original level when i got the unit. should i refill it or just leave at that level?
    thank you!
    Mar 2004
    #748
    any suggestion where i can buy crossbar for our fxt? im planning to put a thule on top for travel.
    Mar 2004
    #749
    Quote Originally Posted by mico_sp View Post
    hi guys!
    thank you!
    shouldnt be a problem as long as it doesnt go below the low level.
    Dec 2013
    #750
    thank you sir baker! will just monitor for the level.
    Sep 2012
    #751
    Question lang po mga sirs. Talaga po ba malakas sa LANGIS ang forester? Unit po is 2.0il, 9k na natakbo. Nakapagdagdag na ako ng 2 1/2 liter ng 5w 30 since nakuha namin. Lagi po kasi nag wawarning yung oil sa instrument panel. Nag start po umilaw yung warning light wala pa po 1600 (1st pms). Sensor lang daw po sabi nila nung una. Pero nadadalas na po at pag checheck ko oil ay malapit na sa low level. Salamat po mga sirs.
    P.S.
    Kung may post na ganito ay pasensya na po at hindi ako nakapagback read. Salamat po uli.
    Oct 2013
    #752
    Hindi yan normal sa kahit anung sasakyan na kumain ng oil ng ganyan karami.
    Yung iba nga 10k km interval bago magchange oil pero ni minsan hindi nagbabawas ng oil.
    Jan 2014
    #753
    *docwin sir , balik mo ulit sa M.I since under warranty pa si forester. Hindi normal yan sir.... Then update us .
    Dec 2013
    #754
    Quote Originally Posted by Docwin View Post
    P.S.
    Sir Docwin,
    may update na ba sa casa kung ano yung problem?
    Sep 2012
    #755
    Hello sirs. Sorry for the delayed reply. I know most of you are in suspense about the oil consumption issue. Ganun din po ako. Just had my 10k pms this morning. They replaced the oil level sensor which kept the oil level warning lighting up. The SA said that it was damaged. The SA also said that the techs could not find anything wrong on why there was oil consumption so what they'll do is to email the concern to their bosses in Japan. I asked him to also send me the reply of their boss. I mentioned that everyone in tsikot is waiting for the update. Hopefully they will answer back. By the way, the SA mentioned that mine was the 4th case of having such concern (though not with a Forester. I think those were brz or wrx if I recalled it correctly).
    Dec 2013
    #756
    thank you sa update doc!
    btw, recently ive been driving windows down and i noticed a "hiss" sound (sounds like air leak) on my front wheels whenever i pass on uneven road or humps. normal lang po ba yun?
    May 2011
    #757
    Baka shocks lang yun bro and its normal...
    Aug 2012
    #758
    I just would like to ask all FORESTER base model owner here, I am in a dilemma of choosing between the XV and the base model of the Forester. How is the fuel consumption of the base model of Forester compared to XV? I really would prefer getting the base model of the Forester sana, but I am just worried because of the bigger and heavy body of the Forester compared to the XV baka kako very significant yung difference sa fuel consumption. TIA.
    Jan 2014
    #759
    Forester NA owner here. Mas okay yata ang fuel consumption ni Forester NA dahil sa new tranny na gamit niya. Alam ko same engine sila ni XV for NA. wait natin yung iba na FORESTER owner.
    Apr 2013
    #760
    Same engine and transmission on the XV and the base model Forester. I think the base forester is only 60kg heavier. So if space is your main priority, go for the forester. If it's fuel consumption, the XV should has a very slight edge.
2014 Subaru Forester
