Page 19 of 82 FirstFirst ... 91516171819202122232969 ... LastLast
Results 361 to 380 of 1640
    Oct 2008
    #361
    Quote Originally Posted by ejaydq View Post
    wow!! ayos mga mods!!! how much did you get the fender flares sa miggys?
    7.5K Bro, discounted price for the TSCP.
    Oct 2008
    #362
    Quote Originally Posted by tancho_kuhaku View Post
    How much damage yung rims and tires mo bro? astig!
    Below 70K bro, courtesy of the haggling powers of Sir Bigblock and Sir LR777.
    Oct 2008
    #363
    Magpapalit na ako mags! lol, congrats sir grantourismo, dimples is looking great.
    Thanks Sir av8or5, wag ka na magpalit. Kung baga yang sayo naka coat and tie, yung sakin naka levi's saka hanes naman
    Apr 2006
    #364
    Quote Originally Posted by dadz View Post
    For any one interested in the OBD2 scanner/gauge and for the performance chip it is available for orders with Tsikot shop for manila area and GO1 for the norther area also with , they will be our tuner and installer.
    Also a more products will be available in few months, inter cooler (for stock turbo), full performance turbo kits, lowering shock absorber for pick up and a lot more.
    *dadz
    pa PM naman ng OBD2 Scanner/gauge, universal ba yan pwede sa other mitsu? or other brand?
    Thanks
    Jun 2008
    #365
    Quote Originally Posted by t3kk3n View Post
    *dadz
    Thanks
    Sir it is not universal since it have to read you ECU. There is some specific box for some cars but the availablity for other cars like sedans is also can be ordered. For the cost po pls do contact sir Jedi of Tsikot Shop (manila area) or GO1 (Norther area) po.
    Jan 2003
    #366
    The OBD2 Scanner/Guage and the “tuneable” Performance Chip work with both the 2.5 and 3.2 engines. Had mine installed during Dadz's recent visit.
    At the Tsikot Car Accessories Shop
    Sir Dadz explaining what the Performance Chip and the OBD2 Scanner Gauge are all about
    Sir Dadz and his friend doing the installation while we watched
    After a series of road tests we ended the test with this climb
    Dadz and I continued with the installation of some other mods at the S4S parking customer area through the courtesy of sir Spyke.
    Jan 2003
    #367
    Today I did some rewiring and fixed the cluttered wires inside the cabin:
    Center console removed
    Rewired the TV antenna booster
    Installed the Performance Chip switch and rearranged the 220V inverter
    Rewiring completed
    Reattached the center console and attached the Boost Controller to the side of the center console. Red switch for the 220V Inverter, black switch for the Performance Chip, and the yellow switch for the socket for additional accessories
    Jan 2003
    #368
    220V x 500W outlet with flip-up cover
    OBD2 Scanner/Gauge and the Boost Gauge that I fixed earlier
    Performance Chip underneath the dashboard and attached to the carpet using Velcro
    Relay switches for the Inverter, additional accessory socket, and the additional steel bumper foglamp. The IPF foglamps have a separate set of relays
    Sep 2010
    #369
    *go1, may mababasa ba tayo sir tungkol dyan sa performance chip na pinakabit ninyo? magkano aabutin yan?
    Aug 2007
    #370
    Quote Originally Posted by G01 View Post
    Quote Originally Posted by leoocampo View Post
    ready for take off na strada ni GO1
    Jan 2003
    #371
    Sir meron po nakapost sa Thai forums (http://www.pajerosportsociety.com/society/index.php?topic=5135.15) regarding this performance chip. Sir Dadz can give you more info about this chip. Pricing haven't been finalized yet but definitely cheaper than the other performance chips being sold by others.
    Dec 2008
    #372
    [SIZE=3]
    Eto ang Winner. In addition to charging gadgets....Pwede na mag hair dryer while on the go.....
    *G01 - sir, Panasonic ba yung outlet?
    [/SIZE]
    Dec 2007
    #373
    Quote Originally Posted by Pol-pol View Post
    [SIZE=3]
    [/SIZE]
    hair dryer.... hmmmm.... nice....
    Jan 2008
    #374
    Quote Originally Posted by G01;16454
    [COLOR=black
    OBD2 Scanner/Gauge and the Boost Gauge that I fixed earlier[/COLOR]
    Eto yung pinaka na gustuhan ko sa mods ni sir G01, inexplain sa akin ni Sir dadz yung function nito.. ganda nito onboard monitoring computer, alam yung fault sa strada mo pati yung turbo boost pressure na monitor mo..
    Pwede rin ma clear yung ma fault sa strada mo..
    Dec 2007
    #375
    Quote Originally Posted by alainroyce View Post
    sana may ganitong gadget para malaman kung nasa 'mood' yung nasa passenger seat hehehe... sigurado sold out agad!
    Oct 2004
    #376
    Yan ang "urban offroading". Hangang side curb/gutter pa lang ako.
    Panalo, sir.
    Jan 2008
    #377
    Tulo laway na naman ako...
    Re: OBD2 scanner/gauge, where else can it be placed? Puede kaya above the A/C switches? Also, bakit -2psi ang boost?
    Jun 2008
    #378
    1 Compressor Inlet
    2 Compressor Discharge
    3 Charge air cooler (CAC)
    4 Intake Valve
    5 Exhaust Valve
    6 Turbine Inlet
    7 Turbine Discharge
    Yan sir boz hehehehehehe if naka neural or idle tayo yung turbine discharge lang ang gumagana going to the tambutso.
    Pag na boost naman po tayo me reading na yung gauge measuring the air comming from the compressor discharge.
    "Engine power is proportional to the amount of air and fuel that can get into the cylinders. All things being equal, larger engines flow more air and as such will produce more power. If we want our small engine to perform like a big engine, or simply make our bigger engine produce more power, our ultimate objective is to draw more air into the cylinder."
    This is from a turbo company so like what i have said in the other thread kahit na anong chip ang ilagay unless the boost cut sensor is modified you will not get the full benefit of the modification, because we need the right amount of air and fuel to have a better power. Most chip will increased the fuel rail pressure but will not open the air pressure since the controller is not modified. A true perfromace chip will let you open the boost sensor so you can balance the air and fuel mixture, proper tuning is required to achieve this.
    Jan 2008
    #379
    1 Compressor Inlet
    4 Intake Valve
    5 Exhaust Valve
    6 Turbine Inlet
    7 Turbine Discharge
    Aprub! Kaya ako bilib sa yo eh. Test mo muna para alam mo kung i-re-recommend mo o hindi. Ayus. Problema lang, isa sa new year's resolution ko eh magtipid... patay na naman kay kumander...
    Jun 2008
    #380
    Quote Originally Posted by Boz View Post
    Pareho tayo sir medyo nakaka pansin na si missis puro test daw ako nag test hehehehehe imagine i have tested 6 commonrail chip and 3 injectors chip and it cost me alot hehehehehehehehehehe buti na lang mabait ako at magaling mag uto ke missis kaya nakaka lusot.
TSCP Strada Mods [continued 2]
