Page 150 of 193 FirstFirst ... 50100140146147148149150151152153154160 ... LastLast
Results 2,981 to 3,000 of 3844
    Sep 2010
    #2981
    Mga ka MB,,may idea ba kyo kung magkano ang cv joint? salamat
    Sep 2010
    #2982
    Sir WheelJack2 gandang araw po, baka may tel number po kayo ni REXTAR pwede ko makuha. salamat
    Jul 2003
    #2983
    Quote Originally Posted by hyundai_rob View Post
    dalawang klase kasi yung outer 1200.00 and 3000.00 dito sa amin laoag city
    #2984
    good day mga mb100'ers... may idea po kayo where available yun hose for fuel return sa mb natin? Tnx po.
    Jun 2011
    #2985
    Quote Originally Posted by reilley View Post
    yung transparent.... sa fronte po meron more or less 600 pesos po ata
    #2986
    hi po sir glen, yun po nasa ibabaw sa may injector ba tawag dun. black na may balot na parang tela. yun from dulo na injector going to the next , hanggang sa last injector...?
    #2987
    Kay jemson ata ako nagpabili nun. May thread sila sa electronics forum. 100 per foot ata? Forgot how much. Common na nasisira siya. Its the same hose on my 1977 benz.
    #2988
    tnx doc sa reply... saan nga po pala yun jemson?
    Mar 2012
    #2989
    sir reilley, sa fronte or apic meron 70pesos each.
    #2990
    809 banawe. Hehe. Two feet ata binili ko for five cylinders. Wala kasi stock sa fronte nun kinailangan ko.
    #2991
    tnx doc , louise17, nun na leak yun return sys ko e nag palit lang ako nun kung ano yun available sa nearest sarisari store ayun parang naging spahgetti sa lambot at nag leak uli... salamat uli sa tulong mga sir.
    Jun 2006
    #2992
    a blessed christmas and prosperous new year to all ! ! !
    Jun 2009
    #2993
    Mga ka MB Merry Christmas sainyong lahat at Happy New Year po!!!...
    #2994
    Help.
    Whenever I park the MB100 overnight, sobrang hard starting sa umaga. Sometimes even requiring more than 5 long attemps. I don't think its the glow plugs since the glow plug fail indicator (glow plug logo illuminates while driving) does not light up. It seems that while parked overnight, the fuel in the fuel lines disappear through a leak or back flow. Yes, there are some drips of fuel (not enough to fill a saucer/platito) on the garage floor.
    When we opened the doghouse, this is what we found. Anyone have a similar experience and solved this problem?
    Dec 2012
    #2995
    mga sir ung clutch kc ng mb 100 ko nag slide ..anu po cause nito anu po pplitan ko.. clutch disc po ba? hndi ko po sure kung cmc or sangyong ung nabili ko panu b malalaman agad.. if for example po cmc lolac ung mb ko.. pwede ko rin po b isalpac ung clutch disk na pang sangyong.. tnx po
    #2996
    Yes cross compatible ang clutch ng cmc at ssangyong. Yung gearing sa loob ng transmission ang magkaiba.
    Pagkakaalala ko clutch disc at release bearing ang pinalitan. Sabay na din gear oil
    Dec 2012
    #2997
    sir pag nagslide po b clutch ko sabay na papalitan ko clutch disc at release bearing ng sangyong po ba? pnu cmc ung mb 100 ko .. wla bang dipersensia.. mga magkanu kya clutch disc sir pati na realese bearing.. hndi b pwede clutch disc lng pplitan ko sir?
    Jun 2011
    #2998
    Quote Originally Posted by eojan View Post
    sir lahat po dapat palitan nyo na clutch disc pressure plate, release bearing, etc....
    AFAIK aabot ng 4.5k sa parts... ang labor nasa 1.5k sa goodgear nyo nalang pagawa at expert sila dun...
    search nyo nalang po dito kung ano ang magandang brand.....
    wag nyo po tipirin yan para hindi tumutonog....
    Jun 2011
    #2999
    Help.
    sir otep parang galing sa O-ring ang leak
    dati nag leak na din sakin dyan... pero hindi ko naman na experience ang hard starting
    Apr 2011
    #3000
    Sir OTEP nangyari na din sa akin yan, o-ring lang yan. Sa akin pa nga pag naka park na nakataas ang harap ng van ng mga 1 day hard starting na.
MB100, Ssangyong/Daewoo Istana [continued]
