Results 2,991 to 3,000 of 3844
- Jul 2007
- 345
December 22nd, 2012 02:22 AM #2991tnx doc , louise17, nun na leak yun return sys ko e nag palit lang ako nun kung ano yun available sa nearest sarisari store ayun parang naging spahgetti sa lambot at nag leak uli... salamat uli sa tulong mga sir.
- Jun 2006
- 73
December 23rd, 2012 10:09 PM #2993
Mga ka MB Merry Christmas sainyong lahat at Happy New Year po!!!...
December 24th, 2012 04:00 AM #2994
Help.
Whenever I park the MB100 overnight, sobrang hard starting sa umaga. Sometimes even requiring more than 5 long attemps. I don't think its the glow plugs since the glow plug fail indicator (glow plug logo illuminates while driving) does not light up. It seems that while parked overnight, the fuel in the fuel lines disappear through a leak or back flow. Yes, there are some drips of fuel (not enough to fill a saucer/platito) on the garage floor.
When we opened the doghouse, this is what we found. Anyone have a similar experience and solved this problem?
- Dec 2012
- 24
December 25th, 2012 10:10 AM #2995mga sir ung clutch kc ng mb 100 ko nag slide ..anu po cause nito anu po pplitan ko.. clutch disc po ba? hndi ko po sure kung cmc or sangyong ung nabili ko panu b malalaman agad.. if for example po cmc lolac ung mb ko.. pwede ko rin po b isalpac ung clutch disk na pang sangyong.. tnx po
December 25th, 2012 10:17 AM #2996
Yes cross compatible ang clutch ng cmc at ssangyong. Yung gearing sa loob ng transmission ang magkaiba.
Pagkakaalala ko clutch disc at release bearing ang pinalitan. Sabay na din gear oil
- Dec 2012
- 24
December 25th, 2012 10:34 AM #2997
December 25th, 2012 12:08 PM #2998
sir lahat po dapat palitan nyo na clutch disc pressure plate, release bearing, etc....
AFAIK aabot ng 4.5k sa parts... ang labor nasa 1.5k sa goodgear nyo nalang pagawa at expert sila dun...
search nyo nalang po dito kung ano ang magandang brand.....
wag nyo po tipirin yan para hindi tumutonog....
December 25th, 2012 12:10 PM #2999
December 25th, 2012 01:06 PM #3000
Sir OTEP nangyari na din sa akin yan, o-ring lang yan. Sa akin pa nga pag naka park na nakataas ang harap ng van ng mga 1 day hard starting na.
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
