Results 1,401 to 1,410 of 5910
October 13th, 2005 10:32 AM #1401
Kakaiba yan #7 sa pag apply at pagtanngal, but it gives great results!!!
Unlike Mom step 2, easy to apply and remove.
- Aug 2003
- 91
October 13th, 2005 11:42 AM #1402Originally Posted by ILuvDetailing
October 13th, 2005 03:43 PM #1403
Originally Posted by delfronda
actually, matagal na product na yang #7.. during the time when single stage paint was the rage.. I still use it from time to time because I like the results. But IHG, VM and Moms SG ako lately...
October 13th, 2005 03:46 PM #1404
Originally Posted by pentot2
watch your ratio when using a APC btw.
October 13th, 2005 10:25 PM #1405
between 3M IHG and #80 Speed Glaze ano mas magandang polish na bagay sa DACP and #26 ko?
October 14th, 2005 10:35 AM #1406
hindi naman polish per se ang IHG eh.
Speed Glaze is actually different from IHG because of its wide functions / uses. it could be used as a polish OR glaze depending on the manner of application.
October 14th, 2005 02:44 PM #1407
dehadista: can u tell us more how the speed glaze be used as a polish and/or as a glaze? in terms of manner of application? tia
October 14th, 2005 04:02 PM #1408#80 Speed Glaze is a great versatile product. aside from fillers, may diminishing abrasives din. if polishing by machine, speed glaze can remove the minimal swirls too. if by hand, halos parang glaze lang. It is meant to be worked until it is almost dry, but still somewhat wet so that it can be removed without smearing. use a MF for removal...
it is actually a mild polish. so to a certain extent, it can be used to remove swirls on your paint because of its diminishing abrasives when used with a machine (Rotary or ROP). so by polishing with this, you are abrading the paint and producing a great shine at the same time. otherwise, you can use this also a glaze during hand applications. pero nakukuha din sa tiyaga alisin ang swirls by hand if you put a little passion behind it.
this is often used after DACP (which is more abrasive)
IHG, as a glaze, is used naman to cover up these same swirls. so parang cosmetic lang. no actual paint correction.
here's the thing: you have to assess first the product and process needed for the condition of your vehicle. it also depends on you on the amount of maintenance, budget and time you're willing to spend in order to preserve that shine.
October 14th, 2005 04:15 PM #1409
It's a polish more than a glaze, you can't have a filler while having abrasives.
October 17th, 2005 12:41 PM #1410
seems like the weather is clearing up lately.. if the weather holds up, sarap mag-all out detail ngayong coming weekend! hehehe.
Coolant...
