Page 35 of 591 FirstFirst ... 253132333435363738394585135 ... LastLast
Results 341 to 350 of 5910
    #341
    you can definitely use DACP / polishing pad with a ROP. these are the same people who instructed me to use speed glaze only on brand-new cars.
    anyway, make sure to work the diminishing abrasives in. you have to do several passes with the ROP. Don't buff till the product becomes a powder. dry buffing na 'yun.. You should always stop before this while there's still a liquid film on the surface. Experience with hands-on practice will help you to gauge when to stop buffing.
    After machine cleaning and polishing with the DACP you need to re-polish with a less aggressive polish and a softer pad. Then apply your wax.
    for Megs products, para sa Pro Line nila, eto:
    DACP and Speed Glaze.
    #66 Quick Detailer (not a QD): "cleaner wax" -best results if used with a Rotary
    Consumer line:
    ColorX : similar to AIO (but not in the same league)
    Deep Crystal Cleaner
  2. #342
    It it advisable to use DACP on a surface with only minimal swirls? Will it thin the clear coat? Can you suggest a less aggressive polish as a 2nd step?
    How about the speed Glaze? Does it contain cleaners or is it strictly a filler?
    Quote Originally Posted by dehadista
    So cleaner wax pala to
    #343
    kung minimal swirls, go for the less agressive product. Speed Glaze. It's a very light polish.
    #80 Speed Glaze is a great versatile product. aside from fillers, may diminishing abrasives din. if polishing by machine, speed glaze can remove the minimal swirls too. if by hand, halos parang glaze lang. It is meant to be worked until it is almost dry, but still somewhat wet so that it can be removed without smearing. use a MF for removal...
  4. #344
    All right! Thanks a lot dehadista. Bisita ako sa Simex. BTW any landmarks near Simex? All I know its along Kamias. Follow up question do they sell the Speed Glaze in repackaged bottles? Finally, whats a diminishing Abrasive? does it thin the clear coat? or just round off edges that cause swirls?
    #345
    BTW, clarification lang for other people:
    magkakaiba mga 'to (all Megs Products):
    #66 Quick Detailer
    #33 Quik Detailer (QD talaga)
    #6 Cleaner Wax
    #346
    ILD: yup. they sell it in repackaged bottles.
    coming from EDSA, along Kamias rd., tawid ka ng Anonas stoplight (may Mcdo and Jollibee). go straight a bit. it's on the Right Side. Big Sign ng Megs. "Simex Trading" ang name nya.
    As it's name implies, diminishing abrasives pulverize as you work them against the finish. When used correctly, this will do 2 things:
    1. Remove below-surface defects.
    2. Remove their own marks as they reduce in size and polish out.
    Yes, like all abrasive polishes, it will thin the CC but not to a considerable extent. (not as harsh as Rubbing Compounds, wetsanding...)
    #347
    Quote Originally Posted by patopig
    Hey masters. I've been shopping around for "consumables" for my new hobby. I got my Moms CA GOLD Pure Carnauba from true value earlier and since I had a lot of time today, I ventured to other smaller hardware stores of some department stores. I found some Soft99 Bi-Gloss cans for only 269!! Kewl! I also found Soft 99 RV (PHP 700++ White container, is that ok for red?) and Soft 99 Le Shen Polymer (Yellow can) and Le Shen Carnauba (Dark Can) for 269 also.
    I know Bi-Gloss is a good bang for the buck wax. I was wondering about the RV (Snow and Mud Protection right?), and the two Le Shens. Anyone familiar with these? I was looking for the Soft99 Sealants (to partner with my Moms Carnauba) but could not find Fusso nor Gekki.
    I also found this Prestone High Protection Wax which is a synthetic wax (supposedly a sealant too). Pretty cheap too.. Anyone try this? I read two positive reviews from autopia...
    what hardware stores did you find those soft99's?
    May 2005
    #348
    Zildjian: The hardware section of Landmark. Bi-Gloss, La Shen Polymer and La Shen Carnauba and RV (White container) were the only ones available. The first three looked new stock but the RV looked like old stock.
    Apr 2004
    #349
    zildjian,
    i think concorde still carries the soft99 products. but last time i was in concorde mega, i was unable to spot my fave Bi-Gloss can. buti na lang nakabili na ako sa SM manila, anlayo
    May 2005
    #350
    I got me a bottle of the Prestone High Protection Wax for 349 (20 fl oz) from Landmark since I read some good stuff on autopia. Two reviews and mentions on the forums.
    http://reviews.autopia.org/censura.p...ils&itemid=290
    Really cheap! Some people are saying this could be a sleeper hit! I hope I get the same results as the reviewers. I now have a sealant to use with Moms CA Gold Carnauba!
    Will post pictures when I get to apply it!
    I will try IHG then Prestone then Moms Phase 3. :D
