Page 305 of 349 FirstFirst ... 205255295301302303304305306307308309315 ... LastLast
Results 3,041 to 3,050 of 3483
    Nov 2017
    #3041
    Quote Originally Posted by G.I. Jaw View Post
    Sir, may I ask, is there an aftermarket solution that can remedy this?
    change mo shock madami aftermarket brand mas comfortable
    Jan 2018
    #3042
    Quote Originally Posted by maxpedition View Post
    Thanks again, sir....
    Nov 2017
    #3043
    Jan 2018
    #3044
    Sir, M/T driver po ako and not so familiar with A/T. Tanong ko lang po kung talagang delay yung response ng 1st/2nd gear/s sa A/T? Some says that you really have to floor it in order for the gear to step up. Is this normal?
    the most scientific test ever
    #3046
    by virtue of its design, there is always some amount, albeit minimal, of automatic transmission slip, when set to the "usual setting"..
    that is why some folks prefer manual transmission; "finger-tip control" daw. well, actually, toe-tip control.
    but the amount of AT slip is usually minimal enough, as to be negligible in ordinary use.
    my opinion.
    i have both.
    Jan 2018
    #3047
    Thanks, dr. d...
    Sent from my SM-A520F using Tsikot Forums mobile app
    Nov 2017
    #3048
    Comfortable yung ranger s loob pero sa labas grabe compare sa hilux.. Malaki factor siguro seat cushion?
    Jun 2017
    #3049
    Quote Originally Posted by zed71 View Post
    thank you sir number001.it works galing mo! d siguro masyado nag lock nung pina tuneup ko. sarap nanaman i hatak fort ko
    Any tips on the replacement of HID bulbs and ballasts for fortuner 2012 to 2015?
    Jun 2017
    #3050
Welcome to all owners of Toyota Fortuner  [continued]
