Results 481 to 490 of 616
- Oct 2016
- 24
- Sep 2014
- 1
November 27th, 2016 09:54 AM #482Hello po mga Sirs/ka-Monty!!!
Pwede din po ako makahingi ng security alarm manual (2011 MS glx). Email add ko po: KooL_JC*yahoo.com
Sinubukan ko na mag-google wala ako mahanap na guide, nag backread na rin po ako, tinry ko mga suggestions, ayaw talaga.
Salamat po ng marami! (:
- May 2012
- 372
December 15th, 2016 01:36 AM #483Just now, im having these problem in my alarm. What was the solution sir? How did you get to fix it?
Sent from my ASUS_T00I using Tsikot Forums mobile app
- Mar 2013
- 2
December 21st, 2016 04:17 PM #484Hi, I need help on my Strada GLS 4x4 2007 central lock/alarm, I know the thread is about Montero alarm, just hoping that maybe anyone knows and can help. My keyless remote doesn't engage the central lock/unlock. It engages the car alarm but not the keyless entry. I have to manually use the key and open or lock the door. It was okay previously but when I had car serviced for maintenance to a local mechanic, when I got it back the problem occured. I asked if they know how to change it back but they don't know. They might have deactivated it without knowing. Hope someone can help. I appreciate it also if the alarm manual can be sent to me, my email is xcx953*gmail.com Thanks in advance!
- Jun 2016
- 1
December 25th, 2016 09:40 AM #485Mga sir nagaalarm mag isa yung monty ko 2012 alam nyo b ano problema neto? Tnx
February 14th, 2017 01:43 AM #486
Kapag nakapark ka lang and patay makina, either nakasaksak ung susi or wala, if u lock the driver side door from inside, nag-aalarm din ba sa inyo?
Gusto ko din sana kase nakalock from inside kahit nakapark ako for safety, kaso nagaalarm nga...
Malamang may nakafigure out na nito so pa-advise naman [emoji4]
February 14th, 2017 08:08 AM #487
My experience bro.,- if you lock the door from the inside (driver's side),- it would activate the alarm or security system, but will not trigger an alarm, unless you open a door.
While inside the vehicle,- did you try locking the doors using your remote? It should just do the above right?
_/_/_/
31.8K _/_/_/_/_/_/_/_/_/_/
February 14th, 2017 08:11 AM #488
Havent tried locking from inside using the remote. I can try this.
Locking manually kase from inside immediately triggered the alarm kaya nagtataka ako kung ganito din ba sa iba.
- Jun 2015
- 2,751
February 14th, 2017 09:11 AM #489Most likely whether you lock from inside or outside, even with the remote, maa-activate pa rin ang alarm.
What you can do is lock from inside and when you're ready to get out, unlock with the remote so it won't trigger the alarm. You may have to have to open a window and hold the remote out.
If you're going to be moving around in the car, you should lock the door with the remote by pressing the lock button twice to get 5 chirps para disabled ang shock sensor.
You could also just leave you car on ACC mode so you can lock without activating the alarm. It probably won't drain your battery that much.
Last option is valet mode.
Mukhang pareho lang pala ang alarm system ng Mirage at Montero. I thought the Montero would have a more sophisticated alarm system.
Tapatalked
- Jan 2011
- 5
February 21st, 2017 07:29 AM #490Hi Sirs,
Anyone of you got a copy of the manual? Pa-send po sana ako: marunillo*gmail.com
TIA!
Sent from my Nexus 6P using Tsikot Forums mobile app
Coolant...
