Results 2,371 to 2,380 of 2560
December 14th, 2015 03:26 PM #2371
- Nov 2015
- 13
- Mar 2008
- 54,258
December 14th, 2015 11:14 PM #2373hindi ho lahat ng bago, ay gumagana nang tama.
may mga substandard or "fake" na items sa mercado.
check nyo kung nag-spark ang mga sparking plugs.. we can start with this.
buksan ang sparking plugs at tingnan kung tuyo at maganda ang kulay.
yung sinabi ni 1d4lv sa itaas... tama yon.
good luck.
- Nov 2015
- 13
December 16th, 2015 05:49 AM #2374Thank you sa mga feedback nyo sir.
Fuel related:
kakapalinis ko lng po ng injector
new denso fuel pump
Electrical related:
ipapalinis ko po MAF and throttle body and then balitaan ko kayo salamat
- Dec 2015
- 1
December 16th, 2015 04:33 PM #2375
- Dec 2015
- 7
December 19th, 2015 08:54 AM #2376Mga sir need help sa lancer hotdog,possible ba kapag sira servo naapektuhan ang spark plug? Idling problem also pag naka aircon,tsaka sobra mausok pag malamig pa makina tapos yun amoy is parang sunog na oil,no usok sa makina no kalansing di nagbabawas ng langis,Pina compresion test ko sabi ng mekaniko good daw 175 lahat butas,actually wala ako idea sa ganun,no need daw for top overhaul,malaki priblema ko lagi na lang ako nagpapalit ng splug cguro since i bought the car rnun april mga 4 times na ako nagpapalit,anyone can help me kung may marecomend kayo expert sa ganyan priblem.tnx
- Sep 2015
- 7
December 20th, 2015 12:03 AM #2377Mga ka-itlog, may tanong lang ako about sa usok ng itlog ko. Kapag naka on ang AC may manipis na puting usok na lumalabas sa tambucho pero pag nag auto off na yung AC dahil sa temperature ng kotse, unti unti nawawala usok. Then pag nag On anjan na naman. Ano kaya ibig sabihin non mga kasama? May problema ba ang AC system or engine? Thanks in advance!!
- Jul 2015
- 198
December 20th, 2015 01:36 AM #2378White smoke while the engine is hot or running na to its optimal running temp is not normal.white smoke is a sign that your engine is burning its coolant or water.tas pag blue smoke the car is burning its own engine oil.maybe kaya ganyan kase when the ac compressor is on your engine is working harder to compensate the power needed to run the ac compressor.
- Dec 2015
- 7
December 20th, 2015 11:42 AM #2379Mga sir dagdag lang sa podt yun spark plug ko kc madali nag iitim,ano rin kaya possible problem
- Mar 2008
- 54,258
December 21st, 2015 01:23 AM #2380
A/c
