Results 2,301 to 2,310 of 2560
August 10th, 2015 05:37 PM #2301
Start with the simpler parts first. Check/replace plugs, HT wires, distributor cap.
- Aug 2015
- 1
August 14th, 2015 02:47 PM #2302help naman mga paps, just recently encountered the same erratic idling issue on my 93 lancer, wherein RPM drops to 200-300 when ac is on and you came to a full stop. Had i it checked by a mechanic sa banawe, no problem with the servo they said as gears where already replaced by kits available, idle control valve was also replaced. It cost me around 3K pero bumalik pa rin problema. sabi nung mekaniko pag bumalik daw problem we need to replace the fuel pump. and it will cost me another 2K. Hingi lang sana ako advice from itlog owners na nakaexpereince ng same problem and how were you able to solve it. Salamat mga paps..
- Jul 2010
- 2
August 15th, 2015 11:59 PM #2303Good pm! Any recommended fuel pump for lancer gli? Except Denso. Salamat! Maingay kasi ung denso na fuel pump na nabili ko.
- Jul 2010
- 2
- Sep 2015
- 1
September 8th, 2015 10:22 AM #2305Help naman mga sir. Tulungan ko lang tropa ko. Baka may nakakaalam sa inyo kung saan makakabili ng wire ng distributor? may kasama na sana harness.TIA
- Jul 2010
- 570
September 20th, 2015 06:21 PM #2306Post ko lang yun DIY HHO Generator na install ko sa Itlog ko para convert yun water into Hydrogen Gas and use as supplement fuel. Gagamit pa rin yun engine ng gasoline.. Mas tipid ay malakas hatak na ng engine at malinisan mga carbon deposits sa combustion chamber.
Ang HHO Generator ay installed ko sa ilalim ng battery. Yun Water Reservoir ay na firewall at yun output hydrogen gas ay dadaan sa Bubbler Container at PVC flashback arrestor.
Then yun output hose ay papasok sa air box para feed yun Hydrogen gas sa barrel ng carburator for Hydrogen ang air fuel mixture..
LOw current consumed ng HHO Cell at di mahirapan ang Alternator na 3A maximum.
Ito yun Youtube Video ng HHO Generator installed.Last edited by Chinoi; September 20th, 2015 at 07:06 PM.
- Sep 2015
- 1
September 21st, 2015 02:24 PM #2307hi,
owner ako ng 95 lancer.. gusto ko sana ipaayos ang aircon kasi ndi na malamig ang binubugang hangin.. magkano kaya ang pagawa nun?
hi,
- Mar 2008
- 54,258
September 21st, 2015 10:50 PM #2308depende po sa sanhi ng hindi paglamig.
kung kulang ng karga, mura lang yan.
kung kailangan nang palitan ang compressor, mga 10K yan.
depende po sa gagawin..
patingin nyo sa talyer, at bibigyan kayo ng estimate. libre.
September 22nd, 2015 12:03 PM #2309
- Sep 2015
- 7
September 26th, 2015 08:38 AM #2310
A/c
