Page 231 of 256 FirstFirst ... 131181221227228229230231232233234235241 ... LastLast
Results 2,301 to 2,310 of 2560
    #2301
    Start with the simpler parts first. Check/replace plugs, HT wires, distributor cap.
    Aug 2015
    #2302
    help naman mga paps, just recently encountered the same erratic idling issue on my 93 lancer, wherein RPM drops to 200-300 when ac is on and you came to a full stop. Had i it checked by a mechanic sa banawe, no problem with the servo they said as gears where already replaced by kits available, idle control valve was also replaced. It cost me around 3K pero bumalik pa rin problema. sabi nung mekaniko pag bumalik daw problem we need to replace the fuel pump. and it will cost me another 2K. Hingi lang sana ako advice from itlog owners na nakaexpereince ng same problem and how were you able to solve it. Salamat mga paps..
    Jul 2010
    #2303
    Good pm! Any recommended fuel pump for lancer gli? Except Denso. Salamat! Maingay kasi ung denso na fuel pump na nabili ko.
    Jul 2010
    #2304
    Quote Originally Posted by gksqaured View Post
    Efi o carb? Palinis mo muna TB
    #2305
    Help naman mga sir. Tulungan ko lang tropa ko. Baka may nakakaalam sa inyo kung saan makakabili ng wire ng distributor? may kasama na sana harness.TIA
    Jul 2010
    #2306
    Post ko lang yun DIY HHO Generator na install ko sa Itlog ko para convert yun water into Hydrogen Gas and use as supplement fuel. Gagamit pa rin yun engine ng gasoline.. Mas tipid ay malakas hatak na ng engine at malinisan mga carbon deposits sa combustion chamber.
    Ang HHO Generator ay installed ko sa ilalim ng battery. Yun Water Reservoir ay na firewall at yun output hydrogen gas ay dadaan sa Bubbler Container at PVC flashback arrestor.
    Then yun output hose ay papasok sa air box para feed yun Hydrogen gas sa barrel ng carburator for Hydrogen ang air fuel mixture..
    LOw current consumed ng HHO Cell at di mahirapan ang Alternator na 3A maximum.
    Ito yun Youtube Video ng HHO Generator installed.
    #2307
    hi,
    owner ako ng 95 lancer.. gusto ko sana ipaayos ang aircon kasi ndi na malamig ang binubugang hangin.. magkano kaya ang pagawa nun?
    hi,
    #2308
    Quote Originally Posted by rajnunez View Post
    hi,
    hi,
    depende po sa sanhi ng hindi paglamig.
    kung kulang ng karga, mura lang yan.
    kung kailangan nang palitan ang compressor, mga 10K yan.
    depende po sa gagawin..
    patingin nyo sa talyer, at bibigyan kayo ng estimate. libre.
    hi,
    hi,
    #2309
    hi,
    hi,
    magtabi ka na ng 15k to be sure.....palit lahat.....
    hi,
    hi,
    #2310
    Have your compressor checked by an AC specialist. Might be dragging power from the engine caused by lack of lubrication, tightened belt or sirang gears. Pag eto ang problem mapapansin mong humihina ang hatak kapag nakakambyo kang natakbo at bigla mong binuksan AC mo
