Results 2,271 to 2,280 of 2560
June 29th, 2015 04:57 PM #2271
June 30th, 2015 12:35 PM #2272
thank you very much, nakahanap ako ng service manual para sa 89 singkit, ayun nabaklas ko at napalitan ng bagong bulb.
sa mga singkit at itlog owners diyan, ito po link, baka makatulong
Index of /mirage
http://www.lilevo.com/mirage/
- Jun 2015
- 5
- Jul 2015
- 3
- Jul 2015
- 3
- Apr 2015
- 8
July 2nd, 2015 10:39 PM #2276Need your help guys, newbie here. My lancer gli itlog when accelerating is making a chain sound.....tunog kadena everytime I step at the gas. ano kaya problema? thanks guys!
July 3rd, 2015 11:10 AM #2277
more details...
a. saan nangagaling? sa ilalim? o under the hood.
b. does it happen kung bukas o patay ang A/C?
more details...
- Apr 2015
- 8
July 3rd, 2015 01:43 PM #2278thanks for the quick reply *1D4LV, its coming from under the hood. it seems it coming from the engine everytime I step on the accelerator. I tried it with or without the aircon may tunog kadena pa rin. Mas malakas sya pag naka 3rd and 4th gear....thanks in advance
July 3rd, 2015 02:02 PM #2279
could be the valves themselves or engine rattle from low octane gas.
have you tried using different fuel? a higher octane one? lets say from 91 octane to 95 octane?
- Mar 2014
- 901
July 3rd, 2015 09:55 PM #2280When was the last time na check ang valve clearance? Baka malaki na gap o clearance ng mga valves sa engine mo. And kapag mataas ang gear position mo at wala kapa sa appropriate speed, at nag-accelerate ka magtotope talaga engine mo. Sa mga manual transmission at carb type engine kadalasan nakaka-encounter ng ganyan mga symptoms.
Sent from my UP+ using Tapatalk
Coolant...
