Page 224 of 256 FirstFirst ... 124174214220221222223224225226227228234 ... LastLast
Results 2,231 to 2,240 of 2560
    Aug 2014
    #2231
    gud day mga idol, ano pwede gawin pagka may leak doon sa filler fuel pipe bracket sa ilalim lancer el94? thanks
    #2232
    Quote Originally Posted by eggtype View Post
    Kung ang leak ay sa fuel filler pipe na tinutukoy mo ay yung assembly na may fuel cap? Like what I did in my EL89, it is worth to buy a new assembly in casa. Nagkamali pa ako sa mga pahinang-hinang sa mga butas nya. Nagkabutas butas sya sa kalawang. In the end bumili me sa casa ng assembly. Too late for me to find out, na mas makamura pa ako kung bumili na lang ako nuong umpisa malaman ko may butas at leak. Nakahigit P900 pa ako sa pahinang welding ng tatlong beses, samantala P1,500 lang assembly nya sa casa. Kabit salpak lang naman din.
    Sent from my Starmobile UP+ using Tapatalk
    #2233
    Jul 2014
    #2234
    Good day mga itlog and singkit experts! Anu-ano po kaya ang mga major at minor cause ng engine oil leak? Para kapag dinala ko po sa mechanic ay hindi naman ako mataga hehe. Salamat po!
    Apr 2015
    #2235
    sir may tanong po ako yong mitsubishi lancer itlog 93 ko pag mag_on na po ako sa aircon lalabas yong indicator sa battery sa dashboard, sira kaya ang alternator ko..................thanks
    #2236
    Quote Originally Posted by tartakobsky View Post
    from the top of my head...
    very minor - loose bolts and screws. all you have to do is to tighten.. but if your threads are loose... heh heh. hindi na minor..
    minor - perished gaskets. open and replace!
    semi-major - hole-y, bent or distorted sheet metal. depends on degree... loose threads around oil drain plug.. may be fix-able..
    major - perished crankshaft oil seal.
    disaster - bent crankshaft! cracked or warped engine block or head!
    good luck.
    Nov 2003
    #2237
    Sir, san may available suspension seat? Brand new or surplus tnx
    Apr 2015
    #2238
    Gud day! New member po mga sirs.
    New itlog owner po 94 glxi. Need ko po ng tulong.
    Nung napa.check ko yung kotse tsaka ko pa lang nalaman na naka.bypass na sya. May problem sa idling. Bagsak ang rpm sa kung mainit na makina lalo na sa tanghali. Laging maitim ang spark plug. Ang hirap gamitin ng auto. Sana matulungan nyo ako mga sirs. Need your opinion badly.
    Yung mechanic na nag.check ng itlog sabi nya may problema ang distributor. TIA
    #2239
    Quote Originally Posted by edudz View Post
    Ipa engine analyzer mo bro. Sa Goodyear servitek meron silang computerized analyzer.
    Apr 2015
    #2240
    Tnx for the reply.
    The last time na.check nung mechanic ung auto pinakita nya sakin ung CEL sending 23 code Camshaft Position Sensor ang tinuturo sa pinakita nyang manual. Diko alam kung saan un at para saan ung sensor.
    Where in Malolos, Bulacan pwede ipa.engine analyze.
