Results 2,041 to 2,050 of 2560
- Apr 2014
- 3
April 29th, 2014 10:42 PM #2041
- Apr 2014
- 4
May 2nd, 2014 04:38 PM #2042Good PM,
Mga Boss auto ko lancer EL ask ko lang if kapag nka aircon ako namamatayan ako ng makina lalong lalo na kapag medyo traffic at tanghaling tapat. ano kaya problema?
- Mar 2014
- 16
May 6th, 2014 12:03 PM #2043Hi to all. Patulong naman. See attached pic. May leak ako nakita sa area na yan. San kaya nanggagaling yan? Ty
May 6th, 2014 12:48 PM #2044
Weird location for a leak. Nasa ilalim ng intake manifold.
Could be oil from valve cover or head gasket na dumaloy down the curve of the manifold. Kapain mo ilalim ng manifold in that area kung basa.
Ok pa ba aircon mo? Could also be compressor oil squirting from the fittings right beside it.Last edited by JohnM; May 6th, 2014 at 12:51 PM.
- Mar 2014
- 16
May 7th, 2014 12:57 AM #2045Yung sign of leak nasa left side po pala, just to clarify. Hindi siya sa side ng compressor ng a/c. Sorry for the confusion.
- Mar 2014
- 16
- May 2014
- 1
- Jun 2012
- 13
May 12th, 2014 12:22 PM #2048Mga bossing ask lang po...san po kaya magandang magpachek ng electrical ng itlog ko...mukang may grounded kasi..pag nag hazard at signal light ng kaliwa pati headlight at ilaw s gauges ngbi blink din xa...mga magkano kaya abutin pa chek nun...on tight budget po kasi kya kelangan ko muna malaman kung magkano bago ipagawa...nwey taga paranaque po ako...tnx po
- Dec 2013
- 11
May 14th, 2014 03:26 PM #2049Magtatanong lang po ako kung ignition coil symptom na po ba ang problema ko. Habang nagddrive po kc ako cguro mag 2hours na biglang namatay ang makina with aircon po pala ako nun while driving. Tapos checkup ko engine kung overheat or anything else, pero ok nman ang tubig and temp gauge, sa tingin ko hindi sya overheating. Nag start ulit ako ng kotse, then ok na ulit sya, this time without aircon, mga after 15 minutes, tumabi muna ako na hindi inioff ang makina, then ini-on ko ang aircon, checkup ko up ko ulit ang makina kung ok, sa tingin ko ok naman, wla overheat or anything. Then when i'am about to go ahead 1st gear p lng nag stop ulit ang makina. Then about couple of minutes nag start ulit ako ng kotse, ok n ulit sya, this time without aircon. Is there any problem with my aircon, electrical or anything... sabi ng napagtanungan ko ay ignition coil daw, umaagaw ng kuryente ang aircon, then pag maiinit na ang coil ay ititirik daw ako nun, may katotohan po kaya un. maraming salamat po.
Coolant...
