Results 1,221 to 1,230 of 2560
- Mar 2011
- 5
March 29th, 2011 01:31 PM #1221************************************************** ******
Central Lock depende sa Quality , pero ako nung nagpa central lock ako w/c is meron na syang existing central inactivate & bought new unit ng cobra central lock umabot ng 2500.oo , cguru budget mo sa 5thou. for central lock,
may napag sabi sakin na pwedi ng i popower steering yang mga manual kaya it will cost u much ranging to 10 -12thou. yan ang sabi skin.... bakit mabigat ba manibela mo?
hope helps u lot......
Betlog////
- Mar 2011
- 5
March 29th, 2011 05:23 PM #1222Ask kolang sir sa mga above user if u have experienced in ur car na may portion na mahinang humatak kahit anung apak mo sa gas ayaw ng humatak?
Tapos pag nag aircon ka naman hinahatak ng makina, pag nag automatic lang dun sya bibira at hahataw uli, i check yung compressor ko parang nirectify nalang, anubang magandang pamalit dun sa compressor for EL97 model, ganito ba talaga pag nag aircon ka hinahatak yung makina?
Anung case ng ganito ? pls help!
Others Advise me to Change Carburator & A/C Compressor.
Any Idea on How much Above Cost?
March 30th, 2011 05:58 AM #1223
- Mar 2011
- 5
March 30th, 2011 06:00 PM #1224************************************************** *
malaki kc yung difference pag umandar A/C sir pag nag automatic naman ok lang pag umandar na A/C parang biglang hinugut ka ganun sya! yung sinasabimung sendan sir may specs ba ito? any idea about sa presyo?
tsaka carburator for 95 EL any idea about sa presyo, balak kung magpapalit sana kc pag umaga 1 click lang sya, but after nun kahit mainit sya hard starting parin.
- Apr 2011
- 14
April 2nd, 2011 12:55 AM #1225Hi there! I'm new here, I just bought a 93 model GLI red ITLOG, ok naman po ang hatak ng makina at tahimik kaso ang problem lang mausok sya, tanong ko lang po ano po kaya problem ng ITLOG ko? Kailangan na bang i top overhaul? Maganda pa naman sya humatak usok lang talaga ang problema ko... Thanks!
- Jan 2010
- 4
April 3rd, 2011 01:46 AM #1226Hello mga Sirs,newbie po ako dito,kakabili kolang po ng Lancer EL 96 model,medyo may puting usok na lumalabas kahit mainit na yung engine,ive check the oil,medyo may konting nabawas after a month na ginamit ko,(3x a week ang gamit ko,about 120kms po every week ang tinatakbo ko) malakas pa po ang hatak at maganda pa ang andar ng makina(sabing mekaniko ko) tanong ko lang po mga sir,advisable na bang ipa top overhaul ko itlog ko?sabi naman kasi nung 1 mekaniko baka valve seal lang daw...help naman po..salamat mga itloggers...mabuhay tayo!!!!
- Jan 2010
- 4
April 3rd, 2011 01:48 AM #1227
- Apr 2011
- 14
April 3rd, 2011 02:03 AM #1228
- Nov 2010
- 8
April 5th, 2011 08:33 PM #1229Salamat sa mga sumagot sa tanong ko.
May 1 pa akong tanong:
Saan kaya ako makakabili ng chrome door handle molding para sa lancer itlog?
magkano kaya?
April 6th, 2011 11:43 AM #1230
mga sir i have glxi 96 A/t problem cold start 1st gear to 2nd gear tagal mag shift,..pag nag shift na sya sa 2nd gear lakas ng tunog "tsug" ganyan ang tunog nya,..pag matagal ng gamit,..nasa 3rd gear na sya,..ayaw na bumaba ng 2nd gear,..kaya hirap umarangkada lalo na pag na traffic halos ayaw ng umarangkada
A/c
