Results 851 to 860 of 2560
April 18th, 2010 01:57 PM #851
some other carb users had no problem of using E10 but I think it will only for a short run.time will come E10 will make their engine burnout that's my personal opinion since this gas isn't really for carb type engine.
if this is happening when you shift to E10 then better go back to what your using before. otherwise have time to bring your car to your trusted mechanic sir.
April 18th, 2010 02:15 PM #852
^yup pag premium gas from uni-oil ang pinakarga ko walang hard starting sa umaga. nung holy week when we went to zambales di ako nakapagpakarga sa uni-oil so I went to Caltex and nagpakarga ako ng Gold worth 1000. Made a stop over sa NLEX Petron (lakeshore before mexico) . After a few meters pumugak-pugak na yung oto and namatayan. Inalog ko na lang yung fuel filter kase tingin ko parang nagtutubig ata yung gas na may E10 pag nakastock lang, experienced no problem after that. On our way to Manila, nagpakarga ako sa may Subic ng walang halong E10. Experienced the same problem pagdating na San Fernando ganun ulit, had to shake the fuel filter, rev hard after starting and nakarating pa naman ng Manila heheh.
Given that, Im not so sure if its E10 related or having problems with the carb. One thing lang ang sure ako pag E10 gamit ko sa oto, hard starting sa umaga and pupugak-pugak and mamatayan pag pinaandar agad. Planning to have the carb checked and fuel filter replaced. Any ideas where I can have it checked? May available ba locally na fule filter that has water separator?
Thanks.
April 18th, 2010 03:15 PM #853
bro I'm not sure kung merong filter na ganun parang wala ata.kahit sang shop yan pwede po. ganun po talaga ang attribute ng E10 me tubig po ng vaporize po yan tapos kakapit yan sa tangke ng gas mo then kakalawangin tangke niyo.dun na start ang problem sa auto niyo.better switch na lang po sa dati niyong gas.caltex dito po kasi samin wala pang E10 kaya yun pa rin gamit ko.
- Aug 2009
- 17
April 18th, 2010 08:08 PM #854Try to check yung Carb Kit (baka may tunaw na kit na po sa loob ng Carb) then try to replace yung Fuel filter ( kahit surplus lang po). Better to check Fuel Pump. Look for Elmer ( AM carb especialist ) sa Kamuning lang po ang shop nya!
- Oct 2009
- 8
April 25th, 2010 09:52 PM #856
aba aba mga itloggers galaw galaw... hehehehe
mga taga san ba itloggers dito?
laguna - batangas representative here...
maganda siguro magkaroon ng tambayan ang mga itloggers ng nakakamustahan ang mga itlog natin. hehehehe
- Jan 2010
- 21
April 26th, 2010 09:50 AM #857from davao city baby! proud to be itloggers! glxi, 1996, midnyt blue... freakin fast and cool ang mga itlog. hehehe
May 4th, 2010 03:30 PM #858
mga itlog braders,
baka meron kayong spare MAF sensor dyan. baka pwede mahiram (or rent) to test sa itlog ko. thanks po.
May 6th, 2010 06:13 AM #859
May 6th, 2010 06:19 AM #860
meron ako kaso sira din paps... hehehehe nagpalit ako ng bago. hard starting ba?ganun yung sakin eh. problem ko ngayon yung check engine indication ko eh. nagpa MUT ako nakita coolant temp sensor, after i check umayos tapos lately bumalik na ulit, ng lo-lose kasi hinugot ko tapos ibinalik hanggang ngayon nalabas pa rin. nag reset na rin ako wala pa rin,kelangan siguro palitan na. hehehe
byd seal5 dmi. that coolant tank is the same setup like in the fords. plastic coolant lines :twak2:...
BYD Philippines
