Results 201 to 210 of 420
June 6th, 2009 10:38 PM #201
Nitro din ang gamit ko sa tires. Last year ko nalaman yan when I was buying new tires at M.H. Miller at West Avenue QC. Nung una ay ayaw ko kasi 50 per tire. Mahal! Pero nang subukan ko ay OK pala. Hindi madaling lumambot ang mga gulong kahit hindi ginagamit yung car weeks at a time. Mas smooth ang ride esp. sa rough road compared to the ordinary compressed air.
Try it!
June 6th, 2009 11:10 PM #202
Tsikot Member Rank 2
- May 2006
- 913
June 6th, 2009 11:50 PM #203amazing how 20% of nitro makes a whole lot of difference on the mind.. after all 80% of normal air is nitrogen.. and i swear by that 80%. its free pa..
- Jan 2009
- 393
- May 2006
- 316
June 7th, 2009 06:50 PM #205replaced tires of my santa fe last feb at yokohama commonwealth ave with an advan s.t. they suggested i fill the tire with nitrogen but i have to shell 40 pesos per tire pero free re-fill naman daw. i asked what is the advantage of using nitrogen instead of normal air, sabi mas maganda daw ang takbo at hindi masyadong matagtag dahil hindi masyadong iinit ang gulong. nag pauto naman ako at pinalagyan ko ng nitrogen. guess what, i still can't tell the difference. went back to have it refilled in April before i did a long drive to isabela and to see if free nga. free nga ang pa re-fill but nothing is free kasi nag tip pa rin ako ng 20 sa nag refill. anyways, 1 psi lang nawala after 2 months pero top up ko pa rin siya to 32 psi. after the long drive i still can't feel the difference. 'yun lang po.
June 7th, 2009 07:16 PM #206
the only advantage i see is that it does not leak out that much, because the molecules of nitrogen is bigger than the molecules of oxygen. but that's about it. unless your tires get punctured, the pressure is consistent.
with regards to weight, i don't see it that way. in fact, i have nitrogens loaded in my tires right now and it runs the same as compressed oxygen air. fuel consumption? still the same.
i have a friend who is an aircraft mechanic who told me that half of the things said on nitrogen on daily driven cars are myths. for one, airplanes requires nitrogen because of the consistency on the pressure if the tires are running on 300 kph. this is the reason also why nitrogen is also used on F1 tires.
but that's about it. my stance is if nitrogen tires will be filled for free, i will use it (as in my case now, because its free when i bought four new tires). but if i have to shell out 40 to 50 pesos for a refill, its a waste of money.
- May 2006
- 316
June 9th, 2009 10:39 AM #207
June 9th, 2009 12:01 PM #208
Advantages using nitro:
Better road holding
Longer tread life, up to 25% increase
Reduced fuel consumption, up to 5% reduction
No corrosion to the inside of the wheel
June 9th, 2009 12:32 PM #209
THE REASON
The practice of inflating tires with nitrogen has been around for a long time. Because of the benefits of nitrogen over air, is has been commonly used in tires on aerospace vehicles, commercial and military aircraft, racecars and off-road equipment.
With advances in technology and the expanding commercial infrastructure of nitrogen availability, nitrogen inflation is a growing trend in the transportation industry.
By far, the single most critical factor for maximizing tire life and minimizing the chance of catastrophic tire failure is maintaining the proper inflation pressure for a given tire size and load. Properly inflated tires not only last longer, but also are safer.
One way to help maintain proper tire inflation is to fill tires with nitrogen instead of compressed air. Nitrogen allows a tire to retain more of its original properties.
Among the benefits of nitrogen inflation: less inflation pressure loss for a more stable, consistent tire pressure; cooler running tires; longer tread life; less oxidation of tire components, and reduced rim and wheel corrosion. The result is increased tire life, improved fuel economy, reduced tire aging and a more durable casing for improved retreadability.
While the trend toward nitrogen inflation is relatively "new" to the truck and bus tire market, it has been long used in tires on Formula One, Indy, Le Mans and NASCAR racecars; commercial and military aircraft; military vehicles; heavy off-road construction equipment, and the Space Shuttle. The Moon Buggy had its tires inflated with nitrogen. Also, the Tour de France bikes use nitrogen in their tires. Nitrogen is environmentally safe and non-combustible.
A reason for the slow growth of nitrogen tire inflation in on-highway transportation has been the availability of nitrogen. However, more and more nitrogen filling facilities are appearing nationwide as on-site nitrogen generators have become more affordable and as more manufacturers of nitrogen generators have entered the marketplace.
THE SCIENCE
Over time the pressurized air inside a tire slowly migrates and permeates its way into and through the tire. Air contains moisture. So in addition to reducing the tire's inflation pressure, the oxygen and moisture in the air reacts with the rubber compounds in the tire, causing them to break down and lose their strength and durability. A chart is available illustrating that nitrogen is the slowest of all gases to flow through a permeable barrier such as a tire. For a copy of the chart please contact us at the number or email address shown below.
An underinflated tire is much more prone to premature failures. That's because when underinflated, as a tire rolls, it flexes more than it was designed to. This flexing bends the tire's rubber and steel (used within the rubber to provide additional operating characteristics) and generates heat. Heat is a tire's worst enemy and accelerates tire wear dramatically. There is a direct correlation between how much a tire is underinflated and how much faster it wears.
Since air, which contains oxygen, is not an inert gas, it is affected by changes in temperature, which affects the rate of air loss from a tire. The air inside a tire expands when heated and contracts when cooled. More air is lost in hot weather. The consensus is that for every 10-degree Fahrenheit change in temperature, there will be a one psi (pound per square inch) change in the pressure of a tire. Nitrogen will not fluctuate as much. Being an inert gas - not readily changed by chemical reaction, nitrogen provides constant pressure and is less susceptible to accelerated diffusion caused by changing temperatures.
Nitrogen inflation minimizes moisture and oxygen in a tire so there is less rubber degradation and no corrosive properties as found in compressed air. A reduction in rubber oxidation slows a tire's "aging," improving the casing's structural durability, lengthening its useful life and yielding a higher proportion of retreadable casings that can survive more retread cycles. All of this helps lower operating costs. Some fleet managers, who had been dead set against retreads, are now willing to use retreads with nitrogen inflation.
Because nitrogen molecules are slightly larger and less permeable than oxygen and all the other gases in air, it migrates considerably slower through a tire. It might take a truck or bus tire inflated with nitrogen about three months to lose two psi, whereas even a well-maintained tire inflated with compressed air will lose, on average, about two psi per month.
INFLATION CHECKS
Just because nitrogen provides consistent inflation pressure over longer periods, that doesn't mean there is no longer a need to regularly and properly check tire pressure. Tires still need to be checked using a calibrated tire gauge and when a tire is "cold" - meaning when a tire is at approximately the same temperature as the surrounding air, typically before a vehicle has been driven, or driven less than one mile.
Kicking or thumping a tire cannot accurately estimate inflation pressure. Trying to determine if a tire needs air by thumping it is as effective as trying to determine if a vehicle's engine needs oil by thumping on its hood.
Regardless of what is inside a tire - air or nitrogen, properly maintaining tires maximizes tire life and fuel economy, and provides improved handling, traction, braking and load-carrying capability. By being more fuel efficient, less fuel is consumed, which decreases petroleum fuel demand and reduces emissions and pollution.
ENVIRONMENTAL BENEFITS
Nitrogen can provide stronger casings for more retreadability, and retreaded tires actively contribute to helping conserve valuable finite natural resources and reduce solid waste disposal problems. Every retread produced means one less new tire, which minimizes the number of new tires that need to be produced annually.
Production of new truck and bus tires consumes large amounts of energy and materials that impact the environment. Truck and bus tires are basically petrochemical products. It takes 22 gallons of oil to manufacture one new tire. Most of that oil is used in the tire casing, which is reused in the retreading process, where only approximately 7 gallons of oil is required to retread that same tire. So each time a tire is retreaded, approximately 15 gallons of oil are saved.
Retreading conserves hundreds of millions of gallons of oil every year, which in today's oil-scarce world is extremely important. And because retreading requires less rubber, fewer rubber trees are "tapped," which helps preserve the natural environment and reduces the loss of natural habitat.
To make the crude rubber used to manufacture tire, workers known as "tappers" make a shallow cut in the trunk of rubber trees and insert a "tap" - actually as small spout - with a cup underneath. Latex containing rubber drips into the cup. The latex is collected and processed into crude rubber.
By extending the useful life of a tire, retreading offers additional environmental benefits. Every tire retreaded is a tire that does not need to be disposed of.
Because every reputable truck and bus tire manufacturer designs and engineers its tires for several retreading lives, only one worn tire casing requires disposal instead of many. The natural resources that are saved and the positive impact on the environment are multiplied.
So are the cost benefits to users of retreaded tries. For most commercial vehicle fleets, tires represent the third largest item in their operating budget after labor and fuel costs. Retreading can cut tire costs in half and sometimes even more.
MIXING NITROGEN & AIR
There is some confusion about what happens when nitrogen and air are mixed inside a tire. By way of example: when a nitrogen-inflated tire needs some additional pressure and nitrogen is not available.
Normal air is about 78% nitrogen; so adding compressed air will simply drop the nitrogen purity. There shouldn't be any adverse affects on the tire or vehicle handling, provided the pressure is kept at the proper level.
The manufacturers of nitrogen inflation system advise that any tire containing both nitrogen and air be purged and then re-inflated with the proper amount of nitrogen as soon as possible. The same procedure holds true in the event that a tire would need to be replaced and nitrogen is not available.
In a situation where a nitrogen-inflated steer tire has been repaired and refilled with air, some nitrogen inflation system manufacturers recommend that the nitrogen be let out of the other steer tire and re-filled with air.
The reason, they explain, is that an air-filled tire will heat up and expand, whereas the tire with nitrogen will not, possibly causing a slight pull to the side with the nitrogen-inflated tire. With air in both steer tires, the air pressure will expand relatively equally, so there shouldn't be any steering issues.
Here again, as soon as possible, the air should be purged from both steer tires and properly re-inflated with nitrogen. There is a small controversy over this point. There are some in the field who believe the effect of topping up nitrogen filled tire with air has too small an effect in handling terms to require such action.
- May 2006
- 913
June 9th, 2009 08:15 PM #210so if you eliminate moisture in normal air(which contains 80% nitrogen) then the benefits of nitro and normal air(which contains 80% nitrogen) doesnt make that much of a difference then. except of course in your wallet..
A few notes: The pit a base model BYD PHEV vs a TOTL Honda ICE. Spoiler: The Honda won, but...
(11th Gen) Honda Civic
