Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 201 to 220 of 420
    Jan 2011
    Ang refill P50/5 tires at honda makati. Also, 3 months na since i last filled with nitrogen, 1psi pa lang nababawas.
    May 2010
    not worth it if you're only doing regular driving. It's only recommended for those High performance low profile tires with very abusive usage. Regular air is already 78% Nitrogen.
    Mar 2012
    nitrogen is lighter and cooler compare sa common o regular air filled tires. if nka nitrogen ka and your driving on a hot pavement your tires are cooler kaya less stress to tire's surface. since mas lighter ang nitrogen, less load din sa engine thus saving you a few bucks in your fuel.
    Oct 2011
    Quote Originally Posted by stavros View Post
    the same holds true for regular air filled tires.
    Jan 2011
    Quote Originally Posted by Retz
    I disagree sir, 3months tapos 1psi lang mababawas? Baka 1month pa lang bawas na yan eh.
    Oct 2011
    monitor ko mabuti. iniisip ko kasi due to uneven pressure high and low pag ginagamit ung tire kaya normal lang na ito ay nababawasan ng hangin.
    nope
    from experience nitrogen-filled tires maintain tire pressure longer
    wrong!
    through experience, mas matagal sa gulong ang nitrogen air
    Jan 2011
    Try mo muna kaya mag nitrogen sir retz hehe!
    Oct 2011
    gusto ko nga subukan. pero may nabasa kasi ako na wala naman daw masyadong benefits.
    ^ pano sir maimprove yung ridr quality?
    Posted via Tsikot Mobile App
    I've never been a believer of nitro for everyday cars. Kung Sa racing pa pwede dahil milliseconds makes a big difference.
    #retzing
    Yep! Isa ako sa sinuwerte, thinking when to claim it hehe
    Sep 2012
    I always fill up every two to three weeks.
    Ang advantage lang for me using this is sure ako na 1 to 2 psi lang nababawas everytime i visit for refill considering 500 to 700 kilometers a week travel ko.
    Pantay din magbawas front and rear tires kadalasan.
    Aug 2013
    try niyo search "fifth gear nitrogen tire test"
    direct comparison ng normal compressed air vs nitrogen filled tires.
    Nitrogen works for me. I usually refill every 5k when I have my tires rotated. It keeps the pressure more consistently compared to air. Tumataas lang ng 2-3 psi after a drive. I check the pressure weekly with my own tire guage anyway.
    If you plan to go Nitrogen, never re-inflate it with ordinary air. The air will just seep out. Check tire pressure regularly. Also, will be practical to have the nitrogen source close by, in case refills have to be done.
    Aug 2012
    If free, why not. If may bayad, nevermind.
    I use regular air lang. I have my own portable tire inflator and digital tire air pressure gauge at home. Even with ordinary air, it takes few months before the tires lose air pressure and need to refill.
    Quote Originally Posted by red_one View Post
    Biggest disadvantage of nitrogen equipped is when your tires suffer a puncture. You have to spend again to have it re-inflated
    Aug 2012
    ^Correct. Kaya ordinary air lang gamit ko.
Nitrogen for Tires [Merged]
