Results 4,281 to 4,290 of 5235
- Oct 2008
- 10
October 30th, 2008 10:25 PM #4281
October 31st, 2008 12:38 AM #4282
Well about injection pumps, I had the scare of my life about a month ago.
Mine is a '05 LS Dmax on its 38thK. One day it just started 'hicupping' when the rpm reaches 1.5k and goes on as if nothing happened after a split second...then again on its 2k rpm, hicupps again and then wala na. Smooth na all the way. Had it check in our local dealer and said its just the dirty fuel system , so we changed the two fuel filters(originals). Well it didn't help.
Now they're talking of fuel injection pumps and that really scared me as I'm passed mywarranty period of two years already. Since the local dealer can't do anything about it, I have to bring my unit to Isuzu Cebu (I'm based in Negros Or.). Fortunately they were able to clean the fuel system, including the injectors (?) in just a days work and its back to normal again.
The verdict?--don't use fuel additives! I've been using petron XCS added with petron fuel boosters since the day I got my unit and this is what I got. THe theory is that the additives really cleanse the fuel but the tiny winy dirt it actually removes passes through the filters and on to the injectors and gets stuck there, thereby giving all those problems---in theory of course.
October 31st, 2008 06:59 AM #4283
October 31st, 2008 03:25 PM #4284
Tsikot Member Rank 2
- Sep 2006
- 1,335
November 1st, 2008 04:23 PM #4285It's probably water accumulated in your fuel-water separator which flowed into your injection pump.
- Jan 2006
- 191
November 1st, 2008 06:52 PM #4286
November 2nd, 2008 12:45 AM #4287
jubilum - so bai, it was the injectors pala? How long did it take you to make arrangements/scheduling with Isuzu Cebu (Ayala)?
I plan to go there within this month for servicing
November 2nd, 2008 03:22 AM #4288
- Oct 2008
- 10
November 2nd, 2008 11:20 AM #4289[SIZE=4]gud day po sa lahat newbie po ako dito sa tsikot.com meron po akong dmax 07' model. tanong ko po kung san makakabili ng aftermarket na grill kagaya nung icon ni srbogoy. thanks po and more power[/SIZE]
November 2nd, 2008 11:35 AM #4290
Yup Dieseldude ----- I check the separators regularly too. So many other possibilities but it seems sa akin lang nangyari 'to. And one very logical explanation must be the diesel power boosters effect which as I have said i've been using for almost three years--wala syang output nang dirt or impurities na in theory na reremove nya...
nagka recall ang BYD last year pero hindi raw affected PH units ...
China cars
