Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
    Mar 2012
    #41
    bwisit na log in yan, pinahirapan ako hehehe, buti na lang may google, na bypass ko na rin
    How to disable login screen on Win 10 | Windows 10 Forums
    pansin ko lang, mas matagal ito mag boot kaysa dun sa win 7 ko
    Last edited by maki mi; August 1st, 2015 at 06:07 PM. Reason: found solution to log in problem
    Oct 2014
    #42
    am still looking for fix =(
    Actual RAM: 2.99Gb
    Minimum Required: at least 2GB
    why such error?
    anyone?
    #43
    Bug. It's still an early release so it happens
    #44
    Quote Originally Posted by maki mi View Post
    Yes, this I discovered while I was tinkering with it yesterday, but golly... andami pa pala!
    "Opting out of all these default settings requires navigating 13 different screens and a separate website, the bloggers have found.
    Well, they're release a lot of products "free". They have to get revenue somewhere. And that somewhere happens to be ad profiling.
    Jul 2004
    #45
    Only bug I experienced so far is the ACS8 Pro file shredder disappeared from the Recycle Bin
    Dec 2009
    #47
    Will try with my legacy devices and apps.
    The laptop ethernet wifi won't connect to my phone...Forever obtaining IP address...:P
    #49
    Ethernet(RJ45) or the WiFi(802.11)?? Try manually with static iP, or if you could PING local and loopback iP. If none of those works, could be a driver problem
    Mar 2004
    #50
    When windows 10 finished upgrading my system, it booted up on the new OS for the first time.
    After logging in, my system was unbearably slow.
    No sounds (error: can't connect to sound hardware). No internet even if connected to the wifi hotspot.
    When I try to launch an app, even notepad, I get an "application unresponsive".
    I struggled to launch the task manager. When it finally came up, I saw my HDD was thrashing at 100% and my CPU was at > 60%. SVCHOST was chewing up my HDD and CPU.
    I got fed up and ate my lunch.
    When I got back, everything was okay already. I got sounds, internet and everything was snappy fast.
    The HDD thrashing stopped and my CPU was down to < 1%.
    Quote Originally Posted by ess View Post
    So what happened bro? Probably the drivers were still being downloaded and installed?
    #52
    Windows 10 is updating in the background.
    Dec 2009
    #53
    Mined the plethora of informations in the computer
    Better do it on a fresh install (format all partitions & dont forget to back up all data first)
    #54
    I stuck with Upgrade rather than a clean install. The netbook hardly had anything installed in it. The laptop and desktop both have a number of games I didn't want to reinstall.
    The only issue I had from all three installs was a terrible slowdown with The Witcher 3 (literally a slideshow). An Nvidia display driver download fixed that one.
    I also turned off or uninstalled a bunch of network sharing/online "features" such as OneDrive and live tiles (in the Start Menu).
    Besides the netbook suffering occasional busy pauses while a web page loads (due to 2Gb RAM and weak Atom CPU), Windows 10 seems okay.
    My main reason for upgrading is a better OS for the netbook and DX12 for the desktop and laptop.
    Mar 2004
    #55
    I did some googling and there was one possible culprit --- indexing.
    It's likely that after the upgrade, windows tried to re-index my files. I have a ton of small files in my HDD (c/o STEAM). And this may have aggravated the re-indexing operation.
    At the same time, it may have also been trying to do other things like initialize the onboard sound, and other services.
    Anyway, all is well. System runs really well, and I'm happy with the end result.
    #56
    I've been testing Windows 10 on this netbook extensively. One thing I noticed at this stage is how much quicker surfing the Web is compared to when I still had Windows 7 Starter installed.
    Before the Windows 10 upgrade, surfing (especially this site) was slow using Firefox (or any browser) because it took forever for the Web site to load. Using the same Firefox with Windows 10, loading Web sites are a lot faster.
    Specs: Intel Atom N550 (dualcore with HT, 1.5 GHz), 2 Gb DDR3 RAM
    It's similar to my old Mac Mini: Intel Core Duo (dualcore, 1.66 Ghz), 2 Gb DDR2, OSX 10.6.8
    The Mac Mini is still better at loading Web pages among low-RAM machines. The older OSX Snow Leopard is a really polished OS. But, my netbook with Windows 10 is right on its heels.
    Jan 2013
    #57
    Win 10 updates keep messing with my laptop's drivers (actually started since I installed my free Win 8 Pro from school - Toshiba E305). Sometimes the ClickPad doesn't work, Blu ray drive won't read CDs, etc.
    My Lenovo Miix 3 on the other hand unexpectedly received the Win 10 upgrade too. Not expecting since I read about the limited compatibility. Better battery life (thanks to battery saver mode) but the default screen orientation is in landscape mode. It lost the auto rotate button in the notif center, reappeared again after a second major update. Got tired of tweaking in the settings. Ang hassle 😓
    My sister has no complains so far from her midrange VAIO, upgraded it even before Sony asked the users to wait until October. I also upgraded our midrange Acer desktop and entry level Lenovo laptop. Speed improvement is noticeable but lag and freezing is still there as expected.
    #58
    almost troublefree upgrade ko from 7 to 10 on my msi gx660. nagadalawang isip pa ako mag upgrade kaso naka tulog ako ng bukas laptop, pag gising ko windows 10 na, walang sound at na iba resolution ng desktop. just needed to uninstall and manually reinstall board drivers which fortunately are still available sa msi website. im also glad its userfriendly as windows 7 and older versions
    #59
    I haven't really tested Windows 10 that much on my ASUS RoG G46VW because it's as responsive as my desktop PC. Everything seems to work fine with the exception of a few old games. The old games will only run in 32-bit Windows 10 where before, they used to run in 64-bit Windows 8.1. The G46VW has the 64-bit Windows 10. No big deal. I can always install those old games on my Toshiba NB305-N600 netbook which has 32-bit Windows 10.
    #60
    so far I have not have big problems after the upgrade.
    except for that my MS Outlook 2010 hangs sometimes.
    dunno if this is because of the IMAP configuration or because of incompatibilities.
Windows 10 - Start Menu is back
