Results 41 to 50 of 83
August 1st, 2015 05:33 PM #41
bwisit na log in yan, pinahirapan ako hehehe, buti na lang may google, na bypass ko na rin
How to disable login screen on Win 10 | Windows 10 Forums
pansin ko lang, mas matagal ito mag boot kaysa dun sa win 7 koLast edited by maki mi; August 1st, 2015 at 06:07 PM. Reason: found solution to log in problem
August 1st, 2015 06:14 PM #42
August 1st, 2015 08:36 PM #43
Bug. It's still an early release so it happens
August 1st, 2015 11:05 PM #45
Only bug I experienced so far is the ACS8 Pro file shredder disappeared from the Recycle Bin
August 2nd, 2015 11:15 PM #46
- Nov 2009
- 3,482
August 3rd, 2015 03:06 PM #48
The laptop ethernet wifi won't connect to my phone...Forever obtaining IP address...:P
- Nov 2009
- 3,482
August 3rd, 2015 03:46 PM #49Ethernet(RJ45) or the WiFi(802.11)?? Try manually with static iP, or if you could PING local and loopback iP. If none of those works, could be a driver problem
Tsikot Member Rank 3
- Mar 2004
- 2,053
August 3rd, 2015 05:45 PM #50When windows 10 finished upgrading my system, it booted up on the new OS for the first time.
After logging in, my system was unbearably slow.
No sounds (error: can't connect to sound hardware). No internet even if connected to the wifi hotspot.
When I try to launch an app, even notepad, I get an "application unresponsive".
I struggled to launch the task manager. When it finally came up, I saw my HDD was thrashing at 100% and my CPU was at > 60%. SVCHOST was chewing up my HDD and CPU.
I got fed up and ate my lunch.
When I got back, everything was okay already. I got sounds, internet and everything was snappy fast.
The HDD thrashing stopped and my CPU was down to < 1%.
It looks like solid state batteries are the next big thing. Will manufacturers allow retrofits to...
All New Toyota Corolla Cross
