Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 138
    Apr 2014
    #61
    I tried wireless repeater setup dati and it gets finicky. Granted asus firmware is buggy.
    Ended up just slapping in a 9dbi antenna on the old tomato router and na solve ang dead spot issues ko.
    #62
    Paano sir gawin ang luma na extra access point? I have an old linksys nung hindi pa uso na naka bundle ang wifi router sa provider.
    There are tutorials around the net. Some routers in fact automatically go into AP mode when you connect the LAN cable coming from the new router to any LAN port other than the WAN port of the older router.
    Sent from my Mi A1 using Tapatalk
    #63
    If you want a reliable range extender, use wired connection in between the routers.
    In my case, 100m limit of CAT5 UTP isn't an option hence i used a line driver with GdotSHDSL capable of 15MB per line extended rates. House A & B is 150m away, I laid the wire along the fence.
    House A modem - Cisco EA2750 - Gdot back2back modem via 150m twisted wire - House B Cisco E1700 bridge mode.
    Aside from the same subnet in house A & B, I get to enjoy movie files connected on USB of router A. The CCTV rides on the same network in a separate VLAN of the modem.
    Sep 2018
    #64
    Direct Tv Bundle
    Cableinternet-deals.com is the provider with the best TV deals, standard professional installation FOR HOME SECURITY SPECTRUM, DIRECT, VIVINT, AND EEXEDE internet. Giving the best deals on Internet and landline and for your own business needs.
    Sep 2016
    #65
    Question mga Sir/Ma'am,
    May effect ba pag nag direct connect ako ng another TP LInk router to our PLDT DSL using CAT5E cable? may ibibigay din po ba yung na wifi signal if ever i-place ko siya sa 2nd floor ng house namin?
    Salamat
    Quote Originally Posted by ReggieMar View Post
    Salamat
    Yes, direct connect via cat5e to main router to extend your wifi signal is so much better than wireless extender... although may signal lost...
    #67
    Salamat
    Depende sa material between the first floor and the second (e.g. thick concrete or wood). Pwede humina ang signal galing dun sa 2nd floor going to the first floor. But then why connect sa second floor router kung nasa first floor ka naman?
    Mar 2004
    #68
    Using another router with WDS capability to extend WiFi range ... Works well ...
    Sep 2008
    #69
    what is the brand and model of the router you replaced it with? your old router is the pldt fiber router?
    Quote Originally Posted by jakewise View Post
    Its the same as repeater... wds so other router/extender can repeat your wifi signal through access points...
    Similar router with the below specs would help to boost your wifi signal...
    https://www.linksys.com/us/p/P-EA9500/
    Sep 2008
    #71
    thanks for the input, quite pricey
    It’s Lynksis... try similar spec with tenda brand, they are cheaper...
    In our house, i used to have extender but sometimes signal/internet drop, what i did is, i relocate the router to the center of our house, luckily may mga signal doon sa lugar na need ng extender... but upgraded my router as well to a better one... yung need lang namin na specs...
    goodluck sir.
    Nov 2007
    #73
    Anyone tried the xiaomi router 3 as extender? Excellent daw according sa customer reviews. Mura pa at 1.2k lang
    Feb 2009
    #74
    I have tried yung 3 and 3c almost the same performance except yung 3c may usb output and an extra lan. The signal is a lot stronger than my other routers (dlink, linksys, tenda, apple) except for the ubiquiti.
    Downside is the parental control is not working. Have not tested for speed but i watch youtube and netflix without any problems.
    Sent from my SM-G965F using Tapatalk
    Nov 2007
    #75
    Quote Originally Posted by joaquim View Post
    Thanks for the reply! My cheap dlink repeater keeps getting disconnected. Upgrade ko sya to this xiaomi as a repeater
    Dec 2009
    #76
    ^if the dlink repeater has a detachable antenna..replace it first with a higher gain (dB)
    Sent from my ASUS Chromebook C202SA using Tapatalk
    My adivse, Just dont buy the one in cdr king... i dont know if its only me experiencing, kasi walang pinag ka iba nang kinabitan ko yung router ko before...hehhe...
    Sep 2008
    #78
    tried replacing my antenna to a higher gain antenna but did not see any difference
    Jun 2015
    #79
    Someone advised me before that a higher gain antenna will widen the coverage but will "flatten" it as well. So, it will reach further on the floor where the router is but the top and/or bottom floor will get weaker signal.
    Jun 2015
    #80
    WDS usually requires similar hardware (same brand, same router model) to work without a hitch.
wifi router
