Results 11 to 20 of 138
October 4th, 2015 11:06 PM #12
- Nov 2009
- 3,509
October 4th, 2015 11:07 PM #13SOHOs are available on IT equipt retail stores in the malls.
Carrier grade if used by Telcos for mass communications are imported tax free. They have authorized vendors that usually carry the support/planning because they are mostly scalable/managed /supports multiple AP,s, have more features. Search na lang po ng vendor like trends.
- Jul 2015
- 198
October 5th, 2015 12:21 AM #14Sir why not ask your DSL company to change your old modem to a new one na may built in WiFi? Less energy consumption kase isang bukas lang.or para sa multi computer use? Computer shop?
- Jul 2015
- 198
October 5th, 2015 12:25 AM #15Sir hinlog,parang wala kong na try na signal booster for WiFi, na try ko na ung mahabang antenna, antenna na parang baron style. Ang ginawa ko na lang I bought a router tas plug sa LAN ng existing one yun ung nilagay ko sa kabilang bahay.
- Oct 2006
- 6,289
October 5th, 2015 04:53 AM #16
October 5th, 2015 09:08 AM #17
Meron wifi booster, known as AP (access points) or repeaters
Those are wifi gadgets with special configuration (WDS or wireless distribution system or bridging) not found on regular routers
Notable physical feature is a single ethernet port
If you intend to connect wifi on 2 distant locations you need to use an external antenna (high gain antenna with sizeable rf cable and connector) for that. Hence, youll need a router with detachable antenna. Antenna located in house will not work even if its a high gain.Last edited by kisshmet; October 5th, 2015 at 09:17 AM.
- Jul 2013
- 2,450
October 5th, 2015 09:44 AM #20Yung TP Link namin almost 10 yers old na ayos pa din.
Balak ko palitan ng model na meron bandwith management para malimitahan ko yung use ng anak ko.
i would expect something like this, if the authorizing authority did not have a clear idea of their...
Suzuki Fronx
