Page 15 of 26 FirstFirst ... 511121314151617181925 ... LastLast
Results 141 to 150 of 258
    Dec 2004
    #141
    I looked into this sharp fan, its price is good(1328 php) , but because of the fan blade design, i'll pass.
    Sharp PJ-S161M(WH) 16" 2-in-1 Stand Desk Electric Fan | Lazada PH
    Curious as to why you don't like the blade design?
    Sent from my SM-P205 using Tsikot Forums mobile app
    Quote Originally Posted by thephantom View Post
    small blades will create lower pressures and volume vs bigger blades(higher surface are) at the same rpm. you won't see 3blade fan on outdoor units like compressors/chillers.
    #143
    Natry ko side by side with other fans when I was buying. Hindi naman mas mahina or mas maingay.
    even asahi is introducing a better fan blade..
    image upload host
    #145
    Mas tahimik naman sila and potentially mas tatagal kasi hindi pwersado.
    we already have this kind from asahi. they want a stronger breeze.
    #147
    I've had one of this since 2013. It still puts out massive blasts of air that cool the room down fast. Don't have any loose paper lying around.
    I haven't had the need to use any other setting except the Lowest Speed.
    Jun 2015
    #148
    This looks interesting. 30W max lang.
    Panasonic DC Inverter Stand Electric Fan F-49SS | Lazada PH
    What I like about Panasonic electric fans is yung oscillation nya smooth at consistent ang speed.
    Compared sa mga Hanabishi, Asahi etc. na nagiging jerky sa katagalan at may slight pause pagdating sa dulo bago siya bumalik sa kabilang direksyon.
    Downside nga lang pag nabasag yung plastic gear na nagpapa-oscillate, mahirap makahanap ng pamalit.
    I was comparing the wattages too vs the normal non-dc 3-4speed fans. This will have lower air pressure/volume.
    The normal 55w fans 1st speed is probably around 15-20w which is low naman.
    Jun 2015
    #150
    I don't like banana-shaped blades as well. Already had 2 of those. Mahina talaga ang hangin at mas maingay.
    I also avoid industrial fans. Talo ka na sa kuryente, maingay pa.
What's the most durable electric fan?/Electric Fans Talk
