Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 258
    Nagbabalian mga electric stand fans namin dito dun sa part where the fan swivels (yung pinaka neck part). Ok pa naman yung fan pero hindi rin magamit dahil lumalambitin na yung fan. KDK brand na mga ito and not those China branded fans.
    Dec 2003
    hmm 3D or Asahi fans are pretty sturdy for their price..itong dalawa main appliance brand carry namin at super bihira lang may warranty claim..lalo na electric fans halos wala
    3D for me. Tried and tested. Also hitachi pero wala na ako makita na ganun.
    Jan 2003
    Panasonic or KDK
    Sep 2004
    Quote Originally Posted by A121 View Post
    Panasonic or KDK
    + 1 on Panasonic ... tuwang tuwa nga ako kasi may nagbigay recently sa akin ng fan na ito.
    also we have in the house 3D, ok naman and yun Standard pinakamatagal ginamit kinalawang na ang blades ok pa din
    huwag daw bibili ng industrial type na fans kasi maingay.
    Mar 2004
    I'm also in the market for a new fan. Loyal Panasonic & KDK din ako.
    Pero I just saw a couple of electric fans that claim to have an IONIZER function.
    Anyone here bought one of those models? Effective ba yung IONIZER feature niya?
    Dec 2004
    Panasonic and KDK are very good. Yung bentilador na gamit ko ngayon matanda pa sa bahay namin.
    As for the plastic used for the blades, I actually find the current "flexible" fan blades to be much more durable than the old "makunat" plastic on our older fans (brittle and easily broken). Metal blades are no doubt durable, but they're also very noisy and dangerous if there are little kids in the house - hence they're more suited for industrial applications. Not that there's any shortage on spare blades - yung bentilador ko dito pangatlong blade na niya ata ito heheh.
    *ess: Ionizers are worthless. They just create harmful low-altitude ozone and do not do much in actually cleaning the air. A CRT TV screen attracting dust serves a better "ionizer".
    Standard. Mine has been working for more than 15 years already. I had to retire it because the blades which were once pink are now white That's how durable it is! I bought the exact same model as replacement. Costs around P900 for the desk fan.
    Jul 2005
    we have 2 3d box fans. the problem is that the gear that controls the grill gets broken and it just goes free spinning. otherwise it's a pretty good fan. national panasonic seems to be the best. is standard still available?
    Baka nasa gumagamit na iyan.
    KDK is already a good brand (it should be because it's worth 2x the price of similar fans).
    3D is also a good brand. 1980's pa yung mga 3D units namin. Medyo baduy na nga ang mga design pero andito pa din dahil useful.
    Maybe you need to use an industrial-type fan. The ones na no-frills ang hitsura. Cool Air, Mitsuboshi and Asahi ang natest ko sa ganitong brand (both for home and work). Wala pa naman nabalian ng leeg.
    Halu-halo elct. fans namin. Merong 3D, KDK at Standard. Yung Standard ang pinakaluma, matibay.
    Meron din kaming industrial fans, malakas talaga. Malakas din sa kuryente....... Nakatago na lang ngayon.
    Sep 2006
    Nabali rin sa neck(dun sa up or down direction ng fan) yun 3D stand fan namin,tandaan ko noong Ultra stampede ng wowowee pinagawa ko sa 3D service center P50. lang pinalit lang yung plastic
    Aug 2004
    3D Retro fan.
    Have three of them. Bought it because the motor is huge compared to the size of the fan... most desk fans have bigger blades and smaller motors... and wear out really fast. The Retro has a big motor, and since it's mated to a small-diameter blade set, it's relatively unstressed.
    Our oldest one was bought in 06. Used almost every day since then. Slightly slower than when it was new, but still very quick at full speed, and has needed nothing but occasional cleaning. Other fans we've bought have lost power or even ground to a stop in just a year or two. The Retro is almost as powerful and as durable as the 3D Industrial Turbo Fan (love those babies), but it looks nicer and the finer shroud grille (which is also very durable) and plastic blade-set make it safer and prettier looking.
    Twice the price of the cheap fans... but worth it. Has lasted four years (and counting)... Fans we've bought for half-the cost only last a year each before needing a rewind or rebuild. Our air out here is very dusty, and we go through fans very quickly.
    Mar 2007
    I have a Dowell, Union, and Asahi fans that seemed to have a stucked up shaft. All are stand fans. We had them all repaired. But what the repair shop told us (if its true), is they replaced the starter capacitors.
    The Dowell and Asahi suffered the same stuck shaft, while the Union had its front plastic plate, where its grill is fastened to, cracked. We threw the Union as junk as I can't find the plastic plate.
    I decided to DIY the 2 other fans, so see if I can get them working. The Dowell seems to respond well to my repair action, while the Asahi, was a tougher one to fix, jammed up the following morning. Good thing I woke up that morning to stop it.
    I had a close call with another stand fan, can't recall the brand, which wasn't spinning, maybe around 3am. I switched it off, but it responded with a spark & a partial burn! Buti lang na-agapan ko!
    I still have a 3 Hanabishi industrial fans, 2 floor types and a stand fan. Still heathly so far.
    Sep 2011
    Ok yung Hunter, hindi nasisira.
    Nov 2011
    Tingin ko matibay din national. Kasi meron kami national dito na regalo pa sa Mama ko ng pinsan niya nung wedding niya. That was 30 years ago. Hanggang ngayon umaandar pa rin. :D
    KDK ok din pati 3D. Never tried others, mahina yung kaha nung ibang brand.
    Yung matitibay noon gaya ng Standard, hindi na ngayon. Better to check the materials used and the overall workmanship. Makina na lang yung questionable. Pero pansin ko lang, mas matitibay talag gamit noon kesa ngayon.
    Planned obsolescence nga siguro.
    Aug 2009
    matibay na electric fan yung solid ang elise. yung bakal talaga kaso wala na ngayon. Standard pa rin kung brand siguro
    sa bahay galit si misis pag tinapat ko electric fan sa akin, steady ko tapos pag lumipat ako ng pwesto yung electric fan linilipat ko din pero yung 'ulo' lang yung may elisi
    Standard parin..2nd is camel..
    ASAHI na lang bibilhin namin japan import daw motor nya KDK isang klaseng electric fan lang sa sm appliances booo
What's the most durable electric fan?/Electric Fans Talk
