Results 131 to 140 of 258
September 22nd, 2020 10:12 AM #131
Thanks for the inputs gents. I think I'll go with Sharp this time.
Asahi 2020 models look awfully nice though. Gives off a warm, vintagey resort vibe.
September 22nd, 2020 11:28 AM #132
Yung Sharp nga matibay, parang 4-5 years na yung isang stand fan namin. Yung desk fan na niregalo ko sa Ate ko eh mga ganun na din katagal. La pa naman issue.
Naiinis lang ako dun sa mga bolt type lock. Hassle pag naglilinis. Mas convenient yung quick release type levers na 3 at isang kumakapit sa taas. Hehe
Sent from my SM-N960F/DS using TapatalkFasten your seatbelt! Or else...Driven To Thrill!
September 22nd, 2020 11:45 AM #133
Nice yan ah. What price range niyan?
Vornado ko conked out after 9yrs of use. Ang ingay ng bearing now. I think nakasira is yung pag add ng lubricating oil ng local Vornado service center. As per manual kasi, do not lubricate daw.
September 22nd, 2020 12:04 PM #134
You can't change fan speed or oscillation with a smart plug. Wanted to add my Sharp stand fan into my smart home environment but on/off lang kaya.
I'm considering this Toshiba fan with digital controls which can be controlled by my smart RF blaster.
Toshiba F-LSA2(W)PH Remote Digital Fan 16inch
September 22nd, 2020 12:14 PM #135
That is true. We keep the fan at the lowest speed and the oscillation turned on in the bedroom and use a smartplug to control its power. I use a routine so it works in conjunction with the A/C.
There's also a fan in the kitchen but this time, the oscillation is turned off.
99% of the time, we're fine with this configuration so cheap fans + smartplugs work.
September 22nd, 2020 03:39 PM #136
September 22nd, 2020 03:58 PM #137
Hehe, need pa talaga Phillips screwdriver eh.
Pero maganda naman Asahi, Japan ang motor niyan afaik lalo na nung unang labas yun pinagmamalaki nila.
Tsaka maganda nga design especially yung brown and black sa 1st pic.
Kung yung sa 2nd pic, kapag nasira motor, dapat palitan lang yun kasi pang-matagalan yung body at fan frame, sayang na itapon lang hehe.
- Jun 2009
- 838
September 22nd, 2020 08:58 PM #138I have an Asahi fan. 18 years old now. May crack na ang case but everything else works fine.
September 23rd, 2020 09:18 PM #139
September 23rd, 2020 10:13 PM #140
I looked into this sharp fan, its price is good(1328 php) , but because of the fan blade design, i'll pass.
Sharp PJ-S161M(WH) 16" 2-in-1 Stand Desk Electric Fan | Lazada PH
in manila, water boils at 100 degrees centigrade. in baguio, water boils at 95 degrees centigrade.
