Page 18 of 22 FirstFirst ... 8141516171819202122 LastLast
Results 171 to 180 of 212
    Aug 2019
    #171
    Ito gamit namin sa bahay. 13 years na pero buo pa din.
    #172
    we use "jett" tankless electric heater.
    recommended by a kakilala in the building industry. we were given the contact number, many (6? 10?) years ago.
    i couldn't find it in the mall.
    it's still ok.
    #173
    Uy pareho lang nga! Di man lang binago yung kaha haha.
    Mas high end nga naman pakinggan yung Stiebel.
    That's my exact heater model as well hehe.
    #174
    Quote Originally Posted by TsekwangBakla View Post
    Panasonics & these above did not fare well nor last long in hard water conditions here. Coupled w/ good softener systems, they should serve as they have you guys in the capital. Your water there is soft from my recollection.
    #175
    but is there a hardwater-resistant heater?
    kasi, by the very nature of hardwater and the mode of heating the water...
    para yang engine radyeythor na ginamitan ng tubig balon...
    #176
    Instant multi-point heaters have much smaller tubes, between the inlet & outlet valves, to slow the flow down as they heat the water passing thru. Hard water calcificifies when heated. Once the scales clog those small diameter tubes, you're looking at either servicing or replacing. You guys are blessed to not have homes sitting on limestone bedrock like ours here are.
    The individual storage only has the heating element, relief valve & thermostat. It heats what's stored. Water doesn't pass thru small tubes. It's not hardwater-proof but trouble-free service life is relatively longer.
    Mar 2004
    #177
    Quote Originally Posted by iandvo View Post
    ok na rin pala. how much did this cost you before?
    7T ... made in Germany ...
    Mar 2004
    #178
    Same lang Stiebel Eltron and AEG, they rebranded lang to Stiebel to appear more high end hehe.
    Stiebel Eltron has always been Stiebel Eltron ... They acquired Electrolux which owned the AEG brand ... for some reason, they rebranded Stiebel Eltron to AEG in some markets and then reverted back to Stiebel Eltron ...
    Mar 2004
    #179
    Install a basic water filter from the main pipe ... helps prevent leaking pipes and toilets ... also prevents stains on glassware and the like ... and watermarks on your vehicle(s) ...
    #180
    what's a basic water filter?
    physical sieve-type filter,
    or ion exchange filter?
Water heater for Showers
