Results 131 to 140 of 196
February 17th, 2020 01:47 PM #131
I suggest that the water heater should be grounded. Had that experience before that there was no grounding and I could feel a tingling sensation when the water hit the skin. Mas masakit kapag ung head ng weenie ang tatamaan ng tubig. It might cause sterility in the long run.
Sent from my SM-N970F using TapatalkLast edited by dreamur; February 17th, 2020 at 01:59 PM.
- Nov 2009
- 3,482
February 17th, 2020 01:49 PM #132
February 17th, 2020 02:07 PM #134
I know this may be too late a suggestion, but could be an option for future planned projects....Where possible, we usually propose to mount multi-point storage heaters close to baths & kitchens along the exterior(instead of in-bath), element-sheltered walls away from human traffic/public view. Maintenance access will be hassle-free. A favor homeowners always appreciate later.
- Nov 2009
- 3,482
February 17th, 2020 04:47 PM #135^Multipoint are usually installed like that, inside laundry closet together with the entrance plumbing and sewer.
For old houses without provision for 20A heater wires and HVAC motors, there's no other way than to lay-out or upgrade the wires and breakers, then utilise the existing shower plumbing.
Most single points need to be accessed to regulate temp, unlike multis that usually plumbed for mixing hot/cold water.
February 17th, 2020 06:16 PM #136
Yup, but it has been a while since we've done centralized heaters, as you may have meant, on residences. Those small capacity storage heaters like the 1 shown is for single bath or in some cases shared by 2 adjacent baths. Where possible, the heater is mounted on the exterior of the served bathrooms. Servicing/swapping the element, thermostat, or the heater itself can be messy....best accessed & done outside.
February 17th, 2020 07:23 PM #137
The multi-point at home is placed under the sink behind the cabinet I have to remove the drawers to access it.
February 17th, 2020 07:31 PM #138
Have seen heaters get blown by pressures too high(happens when main pressure regulators die) on non-peak hours in a subdivision w/ reservoirs up the mountaintops(their main pressure head can go 200ish psi unregulated in some areas). Imagine the mess.
- Jan 2015
- 714
October 19th, 2020 06:49 PM #140Reviving this thread. Sir, would you recommend to use the PPR pipes (white) for all the house piping system or the blue ones will do for most and just use the PPR for those which will be used for hot and cold water?
Sent from my SM-A507FN using Tsikot Forums mobile app
Suzuki JIMNY [merged threads]
