Results 1,681 to 1,687 of 1687
- Nov 2019
- 1,406
April 6th, 2025 02:55 PM #1681
April 6th, 2025 03:29 PM #1682
April 6th, 2025 04:19 PM #1683
I couldn't agree more. I do that "technique" on aircon in our house and cars. But, unfortunately, I'm not the only one using/controlling aircon in our house + almost 24/7 use of aircon in our house 'cause of the kids. I'm just glad a certain aircon service (Teko) is very easy to contact/book a service.
April 9th, 2025 09:16 PM #1684
Fortunately, I got this auto clean function with my samsung aircon in my room.
Also, am doing the cleaning of my outdoor unit. Kahit paano nakaka save ako ng cleaning technician charge.
April 10th, 2025 09:44 AM #1685
I don't know if they've already made changes, but on all the Samsung splits we have, the cleaning mode must be triggered every single time. You can do it in one of two ways.... First, while the A/C is running, you turn on the cleaning mode and when you turn off the A/C, it will go into cleaning mode before shutting down. 2nd way is a bit more elaborate in that, you need to turn on the A/C with the remote facing away (so not 'really' turning on the A/C), then tap on the cleaning mode button, and finally pointing the remote at the A/C and turning it 'off'.
At least sa LG split, the feature can be turned on and it will remember to clean every time you turn it off (until a power failure resets it).
Pero I've relegated all that to a smart home routine where several IR blasters will trigger fan mode on high for 30 minutes.... regardless of what the A/Cs are doing. This method has kept the cleaners at bay for at least an additional 3-4 months.
April 10th, 2025 10:01 AM #1686
Dumudumi pa din naman talaga yun fan roller blade so either way kailanga pa din palinis so kahit gawin yun drying out ng evaporator or hinde in more or less 6 months papa service na din
April 10th, 2025 10:35 AM #1687
It should be repairable. The labels on the tire sealant all say that its a temporary fix and you...
Liquid tire sealant
