Results 1,611 to 1,620 of 1687
- 54,200
June 24th, 2022 09:42 PM #1611
- Jun 2015
- 2,751
June 24th, 2022 10:29 PM #1612From a servicing POV, I agree. Hassle din talaga magpalinis ng split AC.
Social media made y'all way too comfortable with disrespecting people and not getting punched in the face for it. - Mike Tyson
- 54,200
June 24th, 2022 11:01 PM #1613the ceiling-mounted split aircons in the workplace...
they're good, only until they ... malfunction.
after that, for some strange reason, the fixers couldn't get them to function as well as before.
June 24th, 2022 11:38 PM #1614
From those I've tried, they've been pretty good cooling-wise. Though you can mount them higher at the expense of window openings & looks... the exterior louvres & drain pipe won't be as stealth as when they're mounted below the window.
If these were made available here, they would be my go-to AC type.
Sent from my SM-S901E using Tsikot Forums mobile app
June 24th, 2022 11:41 PM #1615
Cassettes...good luck. Drain is always better by gravity than by pump, which those cassettes need.[emoji16]
June 25th, 2022 04:03 PM #1616
Yun bang mga nabibiling a/c na isa lang yung kasamang indoor unit pwedeng gawing multi-split?
June 25th, 2022 05:16 PM #1618
AFAIK, Daikin lang ang may multi split. Pero sabi ng iba wag daw mag multi split kasi pag nagkaproblema yung outdoor unit di gagana lahat ng indoor. Maganda sana multi split to reduce yung outdoor units kaya lang may downside din.
- Jun 2015
- 2,751
June 25th, 2022 06:01 PM #1619
December 14th, 2022 05:16 PM #1620
Top Gear taking a cue from journalists scouring patent applications of tech companies.
Mitsubishi Philippines
