Results 121 to 130 of 1687
November 4th, 2011 08:51 AM #121
Got a couple of Samsung Crystal-S inverters a few months ago; A 1.5 HP and a 2.5 HP. So far so good.
- Aug 2009
- 63
November 24th, 2011 06:56 PM #122Hi meron na ba nakatry ng carrier brand aircon na inverter? They claim that they are almost 40% better compared to other japanese and korean brands.
- Feb 2010
- 578
November 24th, 2011 07:41 PM #123Sa amin 1.5 HP LG window AC 8 years na namin ginamit, anag lamig pa din. very reliable.
- Jun 2010
- 466
November 29th, 2011 04:02 PM #124finally had our split type installed. got a 2.5HP non-inverter LG. so far so good, cools the entire room, including our stairwells in just about 10 mins! let's see how long this goes
- Jun 2009
- 2
January 10th, 2012 08:04 PM #125Just got the new i-power carrier inverter. May question sa mga naka inverter. Namamatay ba ang compressor pag na reach ang temp? Sa akin kasi namamatay. Need your inputs. Thanks
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 21st, 2012 02:59 PM #126if you search google, one of the main difference of inverter AC is that its compressor just change speed as necessary to meet the required room temperature. its compressor does not stop and go lessening the temperature fluctuation in the room which is a characteristic of ordinary AC.
- Jun 2009
- 2
January 23rd, 2012 08:00 PM #127Thats was My knowledge before i bought carrier inverter but now it completely change because it actually turns its compressor on and off when it reach its temp and it is recurrent 10 mins ON and 5 mins OFF. So i wanted to know if other brands like panasonic etc were also like this.
January 26th, 2012 02:06 PM #128
Totoo bang mas makakatipid ang inverter type aircon compared to a conventional? what is the technology or logic behind it?
January 26th, 2012 02:36 PM #129
from wikipedia..........
Inverter (air conditioning) - Wikipedia, the free encyclopedia
The inverter tag found on some air conditioners signifies the ability of the unit to continuously regulate its thermal transfer flow by altering the speed of the compressor in response to cooling demand.
Traditional air conditioners use a compressor that is either working at maximum capacity or switched off periodically, to regulate the temperature of the room. A thermostat is used to measure the ambient air temperature and switch the compressor on when the ambient air temperature is too far from the desired temperature.
An alternate way to meet the varying cooling demand is to vary ("modulate") the capacity of the compressor. An air conditioner compressor has two components, a mechanical part - the actual compressor and the electrical part - the motor to drive the compressor. Either of the components can be used to modulate the capacity. In digital scroll compressors - the mechanical Scrolls of the compression mechanism is controlled to modulate and the electric motor runs at constant speed. The other method is to control the speed of the compressors by various means.
"Inverter" air conditioners use a variable-frequency drive to control the speed of the motor and thus the compressor. The variable-frequency drive uses a rectifier to convert the incoming AC current to DC and then uses pulse-width modulation of the DC current within an inverter to produce AC current of a desired frequency. The AC current is used to drive a brushless motor or an induction motor. As the speed of an induction motor is proportional to the frequency of the AC current, the compressors runs at different speeds. A microcontroller can then sample the current ambient air temperature and adjust the speed of the compressor appropriately. All this electronics of course does add to the complexity and cost. Conversion energy losses from AC to DC and then back to AC can be as high as 4 - 6% for each conversion step.[citation needed]
Eliminating stop-start cycles increases efficiency, extends the life of components, and helps eliminate sharp fluctuations in the load the air conditioner places on the power supply. Ultimately this makes inverter air conditioners less prone to breakdowns, cheaper to run, and the outdoor compressor is generally quieter than a standard air conditioning unit's compressor.[1]
While at the beginning of the 1990s inverter air conditioners had some drawbacks,[2] these have been mostly overcome - the conversion losses are lower and filters suppress most of the electromagnetic interference generated in inverters. Running at full load, a compressor delivers its best efficiency and outperform inverters. Inverter-based air conditioners have their strengths in environments where a partial load is common, as they are significantly more efficient than conventional air conditioners in those situations. For conventional households where each indoor unit is connected to a single dedicated outdoor unit, inverters are the preferred option, as partial loading is the common mode there. The higher initial expense is balanced by lower energy bills. In a typical setting the pay-back time is about two years (depending upon the usage). For more modern installations where an outdoor unit is connected to multiple indoor units there are better options also available.
The inverter principle has been applied to a wide range of household appliances, including microwave ovens, washing machines, and so on.
January 26th, 2012 02:44 PM #130
thanks. mahal lang nga ang initial cost ng invertype aircon. how about the ROI of an invertype aircon? I'm planning to use invertype aircon instead of the conventional split-type. 15 units of 5 TR ea. 15 sqm/TR.
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
