Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 121 to 140 of 168
    Jan 2009
    #121
    saw this on ebay...
    Mini Micro USB DVB T2 Freeview HD TV Digital Mobile TV Tuner Receiver Fr Android | eBay
    Attachment 29609
    it's a dvb-t2 receiver that plugs directly to your android phone or tab.
    wadayatink?
    additional question: has anyone tried to use an ipad or android tab as a monitor for viewing dvb-t output? using an rca-usb adapter?
    DVB-T/T2 will not work here. Look for one that can receive ISDB-T. That's the standard we use here.
    #122
    yep just found out, isdb-t pala ang pinas.
    found this one in olx>>
    Mygica WiTV ISDB-T Digital TV Receiver for iOS Devices For Sale Philippines - Find Brand New Mygica WiTV ISDB-T Digital TV Receiver for iOS Devices On OLX
    has a usb power cord and transmits to ios/android device via wifi. ito na lang siguro bilhin ko since with this i can charge the tab at the same time it is used for viewing.
    #123
    Dec 2009
    #124
    ^i wonder if the antenna is detachable
    Nov 2014
    #125
    Not sure if I understand the question but I'm using a baron antenna sa TV plus (detached the indoor antenna).
    Nov 2014
    #126
    doublepost
    #127
    yup, naka plug lang so pwede kabitan ng antenna na may extension cable. yun balak ko, ilalagay ko lang sa glove compartment yung box and hide the antenna under the A-pillar or stick an antenna to the windshield.
    kaya ko na-research yan kasi yung sync2 ng ford walang tv and dvd and even the usb and aux in will not function when the vehicle is moving.
    now i'm looking to find a way to transmit a digital wifi signal from an rca source to be able to view the dvd playing on the headrest monitors on the tab in front.
    Dec 2009
    #128
    ^its a good gizmo to have in any car then, every passenger can tune in to their favored channels..prevents a squabble
    #129
    Nope, 1:1 lang e meaning 1 isdb-t box connected to 1 device. If ever additional devices can connect they will all be tuned to the same channel. That is why I am also considering, instead of the wifi, usb connected na lang but connected to a wifi box thereby allowing more than 1 device to tune in.
    Oct 2015
    #130
    Maganda ang tv plus sa car, problem ma wire. Mukang mahirap e tago. Mas ok ata ang lcd na may tuner na ng digital. Problem walang special channel ng abs.
    Dec 2009
    #131
    its not as robust as i expected, considering its wifi feature
    Oct 2015
    #132
    If you want that kind of setup. Each tv must have own digital box. The basic connection of digital box is red, white, yellow or rca cable.
    Apr 2006
    #133
    ano kaya problem dun sa tvplus ko? everytime na istart ko siya, nagpapa-scan ng channel. dati naman hindi ganun. nakakabit sa kotse.
    #134
    Quote Originally Posted by wewoy_romero View Post
    is your unit the legitimate version of abs cbn?
    baka "look-alike" model...?
    Jan 2016
    #135
    check mo sa FB group ng tv plus/digital tv, dami info dun
    Oct 2013
    #136
    hay salamat may ka kumpetensya na soon ito overpriced tv plus!
    Transmitter facilities para sa digital Terrestrial TV ng GMA Network, ginastusan ng P416M | Video | GMA News Online
    #137
    I own a TV with isdbt built-in, hindi ko ma-access yung exclusive channels ng ABS-CBN black box, do you thing there would be a way to access them by paying a one time fee to ABS-CBN (outlet)? I do not like Digi-Box since it would just add-up cluttered wires and consume a separate electric power... Do you think this is possible?
    Apr 2006
    #138
    it is the legit one. i sent an email sa tv plus customer care, they verified my unit via serial numbers and such. they sent someone to check on it. nireplace unit na lang nila. good that it was still less than 6 months old and within warranty.
    Jul 2013
    #139
    Quote Originally Posted by Stigg ma View Post
    dati rereklamo reklamo yang GMA na sinasabotahe daw ng ABS yung mga AlDub watchers na naka-TV plus pero yung signal pala nila ng problema hahaha.
    RCA Brand yung 2nd unit ko ng Tv box. Pwde mag-play ng movies at mag-record ng shows.
    Dec 2009
    #140
    Quote Originally Posted by attyallanlatras View Post
    In order to be able to watch exclusive TVchannels from ABS your digital tuner should know the decryption key
    I believe they dont share the decryption key to other hardware manufacturers to force consumers to purchase their digital tuner box.
    What youre asking defeats their intent to control viewership in their favor
    Sent from my GT-P3110 using Tsikot Forums mobile app
Question about ABS CBN TV PLUS (BLACK BOX)
