Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 181
    #61
    ^where did you get it?
    I wonder if they have Bavin powerbanks at the stalls at LCM/168. Are there fakes Bavin powerbanks?
    I got mine at the Cherry Mobile store at Market Market.
    Jun 2005
    #62
    btw, regarding xiaomi powerbank, madami fakes dead giveaway yung black na powerbank. xiaomi doesnt have a black powerbank.
    another way is to charge the powerbank and while it is charging, use the powerbank to charge your phone. if it charges the phone while charging itself, you got yourself the real deal. it uses the texas instrument design/circuit.
    if it doesnt, its a fake
    #63
    ^Can I use this test with other powerbanks as well?
    Jun 2012
    #64
    Quote Originally Posted by sirkosero View Post
    Pag fake nga, masisira na ba ito? Sayang naman
    Jun 2005
    #65
    depends on their design. i can speak only for xiaomi since i researched it when i was looking for powerbanks. sobra hassle dahil dami fake. pyxis na lang kinuha ko. btw, i got a fake 1 before i researched hehe
    if its fake, it will not damage thr device. sobra tagal nga lang din pala mag charge...
    Feb 2014
    #66
    Sulit yung Romoss power bank. Basta yung orig. Tsaka dapat aware sa computation kung ilan talaga yung need na capacity. Common mistakes kasi nung iba iniisip, kung 2000mah ang battery ng phone and 6000mah sa power bank ay makaka tatlong charge sila. More or less mga isang full charge lang or 1 and a half charge.
    Jun 2005
    #67
    from what i gathered, there is about 20% loss sa powerbanks. so if the powerbank is 10000mah (assuming they indicated real capacity), you can only charge a 2000mah battery about 3-3.5x only.
    #68
    ^Depending on the design of the DC to DC converter w/c is a boost and buck ckt. Its basically just a laptop batteries in parallel, the more cells the higher the aH.
    I bought a cheap P150 5600mAh, it lasted only 2months before the converter lost boost. Replaced it with Sanyo Probox 5200mAh, cells are made in japan. Almost a year na, so far so good.
    #69
    The dc to dc converter, a very bad design. Im suspecting board damaged the chip because of visible dirt behind it maybe too tight prints input and output mounts are too close, current creepage shorted the chip.
    #70
    Okay din ba moyou brand? May bavin sa LCM 9000 mah for 1k
    Aug 2003
    #71
    Been looking into Romoss lately, looking for a powerbank for my laptop.
    Tama ba conversion ko:
    My laptop's battery is rated at 50 Watt-hours, good for 8 hours kuno; my adapter's voltage rating is 19.5 volts. Converted to milliamp-hours, it should come at 2500 mAh, right?
    50 watt-hours *1000 miliwatts/hour / 20 volts = 2500mAh
    So in theory, a 10400mAh powerbank should be good for at least 4 full charges?
    Seems the only Romoss powerbank that can do laptops(i.e. up to 20V DC output) is rated at 10400mAh only
    Jun 2005
    #72
    may pyxis na powerbank sa sm north. 890 lang din ang price for 10400mah
    #73
    So which is better? Pyxis or Bavin? I like the bavin digital because it has an indicator on how much more power you have left. The cheapest I saw was 1,250 The regular in 1,100
    Dec 2009
    #74
    intex 5000mah "lithium polymer" for 750petot
    Received 2 xaiomi PB from suppliers.
    Jun 2005
    #76
    bavin is too bulky for me but i am really impressed with it. charges quite fast too.
    if not for the bulkiness and weight, bavin gets my vote.
    Mar 2004
    #77
    Bang for the Buck? If it's just a buck, it will surely Bang!!!
    You get what you pay for so buy the ones with quality even if they're more expensive.
    Sep 2008
    #78
    Anyone here tried Powerbase brand from Malaysia?
    #79
    using Xiaomi 10,000 mah...
    pinadala lang sa akin ni utol from the US.
    here's what I received pero kulay blue
Power Bank: Bang for the Buck
