Page 1 of 4 1234 LastLast
Results 1 to 20 of 75
    Lately, I'm experiencing intermittent internet connection and I found out it was caused by this router. Whenever my browser returns a page cannot be displayed error or something similar, I'll have to turn OFF and ON the router and my internet connection will be back to normal. Can this be fixed?
    Oct 2007
    We have the same problem, im also using a linksys wrtg54g, but di ko alam if its the router or the modem yung problem, kasi meron naman wifi connection but walang internet connection, ganun din ang ginagawa ko, i turn off the router and the internet connection.
    I only turn OFF the router, not the modem.
    I am using the same router but its A-ok over here. Sometimes yeah I have to reset the router by plugging it out but after I plug it in its ok again. And it does not happen veryr often...
    I am not encountering any problem at all with my unit.....
    7505:bravo:
    I have had this problem. I have tried reflashing the router with an update for it's software. Same results. Solution, replaced the router. It was the same story with FOUR Linksys wifi routers located either in my home, my parent's home and at my two PC rental shops. All routers have been replaced by their TP-Link equivalents.
    I am currently using TP-Link brand routers and they have been dependable. Another plus is that TP-Link routers are very affordable. Downside, the configuration isn't as friendly to use but at least help/explanation for each setting is still available.
    So it seems it doesn't have a fix.
    Too bad.
    Oct 2008
    TS, wala ako ma contribute ha?
    dito na lang ako mag ask...
    i am planning to buy a router for my new home. would any of you recommend a good yet reasonably priced router, please? i am planning to buy one today or tomorrow or as soon as globe would be able to install its line...
    also, i need one that's easy to install...easy to troubleshoot.
    gaya nga ng sabi ni GH, try mo muna i flash yung router. if it does not work, then i think its a hardware problem na.
    Quote Originally Posted by ab_initio View Post
    TP-Link. Choose the "N" band routers especially if you are planning to setup a whole new wifi-network. If you are familiar in configuring routers, you shouldn't have much trouble with it. There is also a quick setup option within the router so if you already have the usual information with you, it would guide you through the process.
    few months back, i chose D-Link DIR-615 wireless N. ito highly recommended nung supplier namin dito sa office, sa kanila ko na rin kinuha, unlimited warranty. wala pa naman problema at kahit ilang concrete walls lusot pa rin.
    http://www.dlink.com/products/?pid=565
    Oct 2008
    Thanks a heap, Sirs! i would still go back to this thread just in case i have a problem with my new router...salamat talaga.
    Dec 2007
    Either TP-Link and D-Link DIR-615 are okay. My Linksys WRT300N hasn't given me any problems except 1 or 2 times that it wasn't giving me internet access.
    If you can afford it, connect your routers to good UPS'es or at least surge protectors. Nasira kasi agad iyung isang DIR-615 namin. Pero yung kasabay niyang 3 units, oks pa naman.
    HTH.
    Mar 2005
    i dunno about you but i'm using cheap cdr-king wifi router. plugged on a ups runs straight for months without crashing... pretty good for 1.4k...
    Jun 2004
    using the same router, no problem so far. running 24/7, unless brown out or i need to unplug it
    Dec 2007
    Quote Originally Posted by Psylocke View Post
    Which one is this, sir? Iyun bang N-speed na ire?
    talaga atang problema ito ng linksys. we also have linksys routers before 2 times pinapalitan at buti na lang under warranty pa. ngayon im using d link dir300. ayos na ayos.
    Jan 2009
    i've been using a linksys wrt54gs router for more than 2 years now, that's 24/7, off only during power interruptions. no problems except for the occasional reboot.
    on the other hand, my first linksys, wrt54g, had frequent disconnections.
    Im having the same problems for days na im using linksys WRT 300N
    Napa check ko na nga sa PLDT wala problems modem daw
    might be ang problem is yung DSL parang PLDT ang may problem have
    to on and off my router also to be connected... thats just my observation..
    Quote Originally Posted by Gen. Miting View Post
    eh wala ka sa'kin gamit ko sa internet cafe ng kapatid ko, Encore na tig 1,100 lang sa CDR-King. installed Oct 2k8, no disconnects until now na reklamo brother ko
    Linksys is like PC vs. Mac. too many people use linksys hence, mas malaki ang chances na exploitable siya or like PC, lagi may bago virus. actually, meron nga ako alam na way para ma-pasok lahat ng sa loob ng linksys router na internal network na may naka network share.
    I don't think it's a matter of having someone hacking my linksys routers. My oldest linksys router was pretty stable and actually lasted longer than the more recent batch. I also noticed a general drop in the build quality/features which is kinda a disappointment for a trusted brand name.
    BTW, my PC shop operated from 1999 to 2007 (sold my last shop at end of 2007). In that time, one shop went through THREE linksys routers at an average of 1.5 years a router. Compare that to your brother's six month old router. Before using routers, I was using an old PC running Linux as my shop's internet gateway.
    Oldblue/GenMiting, do you think I care for your opinion on this topic, noob?
Linksys WRT54G problem [merged threads]
