Results 11 to 20 of 35
December 1st, 2017 02:12 PM #11
Really? the point of iCloud security is to protect owners who lost their phone or have it stolen.
If it that's easy what's the point of it?
after restoring it will still ask for iCloud credentials.
Her daughter's been to two CP repair shop and they can't do it.
Punta ka sa Greenhills tell them recovery mode Lang pala gagawin nila para ma bypass yun iCloud. [emoji23]
Sent from my iPhone using TapatalkLast edited by shadow; December 1st, 2017 at 02:14 PM.
December 1st, 2017 02:16 PM #12
December 1st, 2017 02:20 PM #13
The recovery mode can reset your phone instead of restoring. Restore will only work if you know your iCloud account and password. But you can reset the phone completely without credentials. You just lose all data and apps previously stored.
I’m trying to help the TS sir.
December 1st, 2017 02:25 PM #14
December 1st, 2017 02:26 PM #15
Question for the TS, did you activate Find My iPhone Activation Lock? If not, you can use restore mode to reset your phone.
If you did, you will need your iCloud credentials.
December 1st, 2017 02:28 PM #16
December 1st, 2017 02:32 PM #17
Kung naka on ang Find my iPhone, pwede pa mag work ang Restore. Kung naka on lang yung Activation Lock yung magiging problem.
I was trying to help the TS with a possible solution instead of outright stating na walang pag asa.
- Oct 2017
- 95
December 1st, 2017 02:36 PM #18Grab a phone with IDD and call Apple US customer service and ask to have the Apple Cloud password reset. Make sure you have your wife nearby in case they ask some questions about the account.
The iPhone will always be attached that that profile's account regardless of how many factory resets you do. (It wasn't always like that though) Hassle sya kung nakalimutan mo password mo but it's a good security feature where the iPhone is quite useless without the matching account.
December 1st, 2017 02:39 PM #19
December 1st, 2017 02:42 PM #20
You found your iCloud credentials?
You can reset your phone through iTunes then. You’ll lose all your data though.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
