Results 21 to 40 of 53
    #21
    Hi,
    In most cases a 'product recovery' CD/DVD will restore the computer to the original state when it was first purchased (the OS, Drivers, Applications). You will loose all personal data and applications that were installed after purchase.
    how many HDD partitions do you have? if you have ample space left like at least 1.5(GB) of available space on the hard disk you can install another win xp home edition in a different partition not on the onew where the files are located ...after which access the files you need and back them up on your flash drive HTH ;)
    #22
    may tama na yung HD mo dun sa part ng boot disk containing windows kaya di natutuloy ang boot up. happened to me once, on a very old HD. your laptop though may still be serviceable by simply replacing the HD with a new one. here's some steps you can do:
    1. boot up windows from a CD, USB or external drive. then see if you can still open your HD. IF the only problem is the boot section of your HD then you may still be able to access your files by booting up windows from another boot disk (i.e., Windows boot up CD).
    2. if you don't have a boot up CD or USB drive, then you can use an external HD enclosure. remove your laptop's HD, install it in the external enclosure, then access it using another computer. IF it can still be read then you're lucky.
    if the HD can not be read anymore then the only other course of action is to bring it to a very specialized shop who will open your HD, remove the disk and they will then extract the data bit by bit. VERY EXPENSIVE.
    Thanks for the advise. I'm trying to avoid bringing it to a shop because of my private data and I need to save as much as I could since I am forced to purchase a new laptop. The diagnosis alone costs 1.5k to 2.5k already! I could only imagine how much it would cost to extract the data.
    #23
    Quote Originally Posted by erj22 View Post
    BSOD - blue screen of death? laptop ba? siguro naman di mo nabagsak yan. sundin mo rin yung mga advice ng ibang nag respond. you may also want to check these:
    I thought I had to sign up pa in a technical forum. Andito na pala lahat ng expert! It's a Toshiba laptop. It's very abused na. Natapunan na nga ng half glass of water pero I just kept in a sack of rice for 2 days and it started working again. Di pa naman siya nababagsak. Tingin ko marami na rin virus yung laptop ko. Parating hang and I can't even restart so I just turn it off without shutting down or pull the plug.
    Quote Originally Posted by rukawa11 View Post
    marami ang dahilan ng bluescreen pwedeng sa software application or hardware, pag software try mo uninstall mga new application na nadownload mo at ininstall. or restore ka sa date na maayos pa ang lahat, kung hardware naman pwdeng madumi lang ang memory card at need lang linisin, or kung hardisk drive naman baka sira na, malalaman mo kung sira na hardisk drive pag laging nag ha hung at biglang bumagal ang pagandar ng computer mo. try mo palitan HD mo kung ganun.
    kung di mo maopen laptop mo, try mo palitan HD mo tignan mo kung nagana sa ibang HDD. pag gumana ng maayos replace mo na yan, Toshiba laptop mo malamang toshiba din HDD o, yan ang sira ng mga toshiba eh yung HDD nila, ganyan nangyari sa laptop ko nasira agad HDD toshiba, buti nalang may warranty.
    mukhang hard dick nga! My laptop hangs a lot and it's so slow! I thought it was a ram problem since I've only used less than 25% of my HD capacity.
    #24
    I can't access safe mode anymore. I just want to back up my files. If my laptop will still work after, It'll be a bonus for me na lang.
    Yes I'm looking for someone that could help me. I won't try to disassemble the laptop kasi may history ako na hindi ko na mabalik mga binaklas ko
    Wow galing!!! I tried the F8 and this is the message that I got:
    Attachment 18305
    I tried the following options:
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Command Prompt
    Last Known Good Configuration
    Start Windows Normally
    But I would still go back to the same blue screen message.
    How do I use the recovery CD? I was given 2 disks when I bought my laptop:
    Microsoft Windows XP Home Edition
    Toshiba Satellite Product Recovery DVD ROM (Is this the recovery CD)
    All my files are at My Documents and Desktop lang
    Using the F8 command will not really do much at this point because the system's OS is corrupted beyond self-repair without outside assistance. Using the recovery CD will result in the entire HDD getting re-formatted in the process and wiping out all data on the HDD.
    The only real best option to simply recover your files is to remove the HDD from the laptop and use a connector so a working PC can read the contents and recover them. The "connector" depends on the type of HDD your laptop has. If it's current tech like SATA, it is as simple as gettng a cheap USB HDD enclosure. But as I have mentioned, chances are it could be using PATA type connector (which is the predecessor of the SATA system). There are PATA/IDE adapters but it might be hard to find one these days. I don't know if there are PATA/USB adapters.
    There are many other ways to get your data but it requires someone with a bit of knowledge and some prep work too.
    #25
    Quote Originally Posted by BoyBawang View Post
    Hi,
    I think I have that DVD. It says Product Recovery DVD Rom. I have no idea on HDD partitions. I only know that my laptop has an 80 gb Hard disk. I used less than 25% of it.
    #26
    My friend told me that he could try to fix my laptop, just bring my Windows installer, recovery disk and drivers (?). BUT since you mentioned that my data could get wiped out, I am hesitant na. Does that mean I have no other choice but to bring it to a computer shop?
    #27
    Have you ruled out the possibility that only your boot loader is broken? With the Windows installer CD, there's an option to repair your existing installation if it finds that the bootloader is still repairable.
    Though given the way you use your laptop and its sheer age, it's also very possible that the drive is simply just dying. Best to take it out and save all your files before the entire drive conks out. Then you can decide what to do from there - you can reformat, you can try to have it repaired, you can get a new hard drive (a 2.5" 1 TB hard drive would set you back roughly 4k), you can upgrade to an SSD (180 GB SSDs are now only 6.5k), or you can get a new laptop altogether.
    #28
    Pag dinala mo yan sa computer shop, you do run the risk of them accessing your files and stealing private stuff (if you know what I mean). Best to have a knowledgeable friend do the recovery for you. Unless you have nothing to hide.
    #29
    I really have no idea? IT talk sounds greek to me
    I've already decided on getting a new laptop but I still need to recover my files. I really don't want to spend so much on the repair of my laptop since my new laptop is an unforeseen expense for me. It would be great if my old laptop could still work so I have a spare laptop. I don't think anyone else would want to buy it anyway given its physical state. hehe.
    This is the primary reason why I do not want to bring it to a shop. My college ex used to fix my computer but we're not in touch anymore. Even so, I still have some files that I do not wish for him to see.
    #30
    If I were in your case here are the things I'd do:
    1) Retrieve whatever can be retrieved from the current drive. Any friend with a little technical know-how can unscrew your laptop, take out its hard drive, plug it into his desktop, and copy the files.
    2) Get a secondhand hard drive for your laptop. These wouldn't cost you more than 1k, as long as you stick with the smaller sizes (160 GB and below).
    3) Get a new laptop. Personally I'd allot 35-45k for this, but if you don't run demanding programs, the basic laptops which are roughly 25k would be good enough for you.
    #31
    *jut703 Can I do option 1 without the PATA adaptor?
    Aug 2011
    #32
    yan na nga ang issue mo. parating hang could be a symptom of spyware / malware (sa madaling salita, virus). bakit parang nag hahang? kasi the perpetrator is trying to find a port and at the same time a network connection para masabihan yung author ng virus na eto ang info, blah blah. kaya mabagal. pag naramdaman na ganun, parang hang, shut down o restart yung pc by improper process. mukhang dumalas, hard disk naman nagka issue. di kasi napapark yung drive head properly kaya may tendency yung drive head na tumama sa platter. imagine yung old school vinyl record player. yung reader niya nasa gitna ng record. nakalog yung player, gumalaw yung reader, kayas yung vinyl record. yung distance kasi ng platter sa drive head ng hard drive is makapal pa ang hibla ng buhok natin. mag simula sa bad sector, bad cluster hanggang sa mag physical error.
    Aug 2005
    #33
    so what are you suggesting then to the poor laptop owner
    Jul 2006
    #34
    OT:
    Wow, this one I never knew .. hats off to you Cathy!
    #35
    Product Recovery CD usually for re-installing the OE only like factory out-from-the-box progams, seldom does it contain content-recovery program or similar ghost service. There's high chances that you can still recover the files since the boot recovery option is present, you just need to patch-up the boot files that were corrupted/damaged.
    Was the folder My Documents set to private mode? If that is, it will be encrypted and you will not be able to recover the files easily by docking your hardisk to another computer.
    Heres additional things you can do
    - Enter BIOS(F1, F2,F12, esc yata sa Toshiba) set boot priority to optical drive, save and re-start. Run recovery CD and look for the recovery using Restore Point. Set the oldest restore point - that will wipe-out all newly installed programs in the registry but will retain your personal files. Do it with caution since one mistake or selecting full-HDD recovery could mean byebye to your files..
    - Try booting on command prompt or DOS shell. That will give you additional options like scandisk,defrag, manual copying of files, some patching of damaged files. This maybe possible using a floppy drive/disc with DOS 6 or higher and some knowledge of DOS, soo old procedure but sometimes helpful.
    - Buy your new laptop. Do a research on how to remove HDD from your old lappy (usually its held by philips or torx bit fasteners).There are video and guides on the net for a tear-down process that usually shows installation is just the reverse of removal. Remove HDD, check the interface type, go to CDR KING and get appropriate enclosure or tool. Plugin the external enclosure to your new laptop and access directory, copy desktop mydocuments, run disk-utility checking tool to fix bad clusters.
    That i think are your best options for now, beyond that you need to learn more tech stuff. The risk of losing the file will be high since it will be a trial and error for first timers. I've recovered files of my coworkers laptops and most difficult ones are those with damaged hardisk. I suggest you buy new PC or lappy asap, make your old laptop as backup if you will be able to fix it. Nowdays its practical to maintain 2 personal computer/laptop just for the sake of data backup/recovery.
    #36
    am i reading it right?
    haha
    nag Freudian slip si Cathy
    #38
    Was the folder My Documents set to private mode? If that is, it will be encrypted and you will not be able to recover the files easily by docking your hardisk to another computer. .
    I'm not sure but it's just the default setting. I did not make any changes when I bought my laptop.
    I'm going to buy a new laptop this weekend. I really hope I could recover my files. It's so hard because most of the people who are really good in computers that I used to rely on have left the country already. I hate Brain drain talaga!!!
    Thanks everyone for the replies. It's comforting to know there is a chance I could still get my old files back
    #39
    Quote Originally Posted by kinyo View Post
    haha
    common typo! lol!
    #40
    Depends on what resources/hardware your friend has. And I don't know his plan. If he can connect your old HDD to his computer so he can backup your data, then problem solved. If he can boot up your laptop with a boot-USB drive or Windows-on-CD configuration, he might also be able to copy your files to an external drive. There are many ways to do it.
    As for your friend asking you to bring the installer, drivers, etc, I think he is just assuming he can reinstall Windows on your old laptop AFTER safely backing up your data to a safe place.
HELP PLEASE! Windows Blue Screen of Death?!?
