Results 11 to 20 of 52
August 27th, 2006 06:09 PM #11
CPU - 39 deg.C
mobo - 38 deg.C
PSU is 350W, running a P4-2.4GHz overclocked to 2.7GHz.
the computer's been on for the whole day na and it's got the cover closed, no chassis fans, sa PSU lang and stock p4 fan and heatsink.
August 27th, 2006 06:15 PM #12
p4 na 3.2 ghz core temp right now is 46 deg. c!
Pc has been runing for about 24+hrs now!
August 27th, 2006 06:49 PM #14
CPU Athlon XP 2100+ = 48.1 C
Vid Card Nvidia FX5200 = 43.2 C
Motherboard = 35 C
PSU (generic 350watt) = 38 C
- Aug 2004
- 243
August 27th, 2006 07:01 PM #15
Sir,
I advise you to put auxiliary fan and change your current processor fan.
Maiinit talaga sempron, though d ka magkakaproblem it will shorten the cpu life and sometimes it can crash (BSoD)
Some Mobo can withstand extreme heat while others cannot so it also depends on your mobo.
August 27th, 2006 07:02 PM #16
bakit lalamig ng units nyo ata...50-60 deg ung sa server, 1/2 on na siya, open case, tutok sa fan...
August 27th, 2006 07:04 PM #17
August 27th, 2006 07:11 PM #18
Computer temperature depends on the ambient temperature. If the room is hot or not well ventilated, then the CPU's temp would tend to be warmer.
Is your server located in a small room or enclosed in a corner with minimal ventilation?
My CPU's case has a "delta" fan replacing the original case fan. The delta moves four times more volume of air than the original. Although it's also noisier, I can manually throttle to be slower (and quieter) if I am not doing processor intensive tasks. If I am playing my games or doing some video/image editting stuff, it's full throttle.
August 27th, 2006 07:25 PM #19
kulong tong shop,e.. full glass and the only opening is the door.now ok pa naman, eto na gamit ko.. tututukan ko nalang ng small fan para di maginit masyado...
- Aug 2004
- 243
August 27th, 2006 07:35 PM #20put inflow and outflow auxiliary fan and replace the fan cguro. dami naman aftermarket dyan na pang amd.
Buy adhesive remover or try the Johnson's baby oil approach. See if it works for you.
Removal of Rain Visor and Chrome Door Handle and...
