Results 1 to 10 of 52
August 26th, 2006 06:07 PM #1
ask ko lang, anu normal working temperature range ng system and CPU?
mines sempron2200, replaced ko ung CPU heat sink, kasi nasira ung clip for the CPU fan.
sa bios, the CPU is registering 45-53 deg.C and the system goes from 20-30deg.C with the cover on.
is this normal?the fan is registered to be running at 4680-4710rpm.
naglagay me ng thermal paste, pero di ko sure kung kulang or sobra, basta mga approx. 1mm bead nilagay ko sa center ng processor....
August 26th, 2006 06:09 PM #2
my athlon64 3200 2.0ghz overclocked to 2.2ghz is * 50-60 degrees no prob.
August 26th, 2006 06:19 PM #3
di ko matandaan ung temp. nito before the change, pero other pcs (atlon 1.6) ko 35-40 deg. lang,e....
now 31 deg.C ang system, 53 deg.C ang CPU...
nag hang, resetted,pero no display 1x..
then turn off, the on ko ulit, ok na....nang pinata ko, yan ang nakuha ko parin 31 deg and 53deg.Last edited by alwayz_yummy; August 26th, 2006 at 06:46 PM.
August 26th, 2006 08:54 PM #4
my 2.4Ghz is playing around 40-45 degrees. its always on (24/7) pero tinanggal ko naman na kasi lahat ng covers.
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 26th, 2006 09:05 PM #5you're fine yung sakin laptop with 1.6 turion goes up to 60 degrees before undervolting, it got as hot as 68.
August 26th, 2006 09:20 PM #6
yan ang reading kanina...may inad-just ako, 50's na now..pero open case..test ko tommorow pag closed case....
August 26th, 2006 09:27 PM #7
CPU Temp: 66C
System Temp: 43C
Processor: P4 3.0
Power Supply: Task 450 Watts
August 26th, 2006 09:35 PM #8
My P4 2.66 GHz system registers average temp of
CPU 38-45 (even 65 when CPU is at 100%)
Motherboard 35-40
August 26th, 2006 09:42 PM #9
masmabilis pala uminit ang AMD processors compared sa pentium 4's,e...
comparison ko sa server and cpu ko sa room...
August 26th, 2006 09:47 PM #10
A/C is off right now with room temp at 27C. Without A/C, idle temp hovers at 42C and have gone as high as 52C. With A/C, idle was 35C and maximum temp was 47C.
Athlon X2 4200+ with default fan
MSI K8N Neo4 Motherboard
I do need to clean out the dust inside. It's over a year old and hasn't been cleaned inside yet.Last edited by Jun aka Pekto; August 26th, 2006 at 09:51 PM.
Buy adhesive remover or try the Johnson's baby oil approach. See if it works for you.
Removal of Rain Visor and Chrome Door Handle and...
