Page 16 of 48 FirstFirst ... 612131415161718192026 ... LastLast
Results 301 to 320 of 954
    #301
    Headset din next target ko ng pwede na ko sumali sa online multiplayer ng World War Z. Hehe
    That is some flex bro. Galit ka ata sa pera.
    work from home bro. mas masaya kung hindi naririnig ang mga kausap mo hahahha
    8000 pesos for this 6C/12T cpu. They're really shaming Intel lol
    You can now grab the 6-core/12-thread Ryzen 5 36 for $16 - TechSpot
    Lucky to see an option in my lenovo to only charge the laptop up to only 60% when plugged, since it usually remains plugged 24/7.
    Jan 2009
    #305
    Would you say that these are a good match?
    MSI X570-A PRO
    AMD Ryzen 5 3600X
    G.SKILL RIPJAWS 16GB DDR4 3600 2x8GB
    Just want to upgrade these three items and reuse the other parts (Case, PSU, SSD/HDD, GPU), for now.
    Primary use is video editing and general purpose PC.
    Jan 2016
    #306
    What's the benefit of this? Di nga ma overcharge but hindi ba masama rin na undercharged? I think I read before that the ideal charge level is 90%?
    Jan 2009
    #307
    For Lithium batteries, ideal is 40-60% or roughly, half-full. This is the sweet spot to minimize wear on the battery when not in active use (ie. always plugged in).
    Just charge it to full when you have to.
    It's a good feature to have. I wish all laptops have this.
    Jan 2016
    #308
    Have to check if mine is capable of this feature
    Jan 2016
    #309
    Quote Originally Posted by kakabakaba_kaba View Post
    May ma-recommend ba kayong shop na magcheck ng macbook pro. Pag boot may lumalabas na folder with question mark. TIA
    May update po kayo, if napa ayos nyo na, ours won't work na rin, nahinayang naman ako.
    Yours is thinkpad? Kind to share where we can have that option?
    #311
    The advice in tipidpc is to plug your laptop to ac outlet to prolong the life of the battery, and never let the battery drain below 50% before charging and that includes mobile phones.
    Jan 2009
    #312
    Below 30% is my danger zone.
    You are aware that rechargeable lithium batteries are most stable at around 50% SoC, don't you? They start to lose life at either end of the scale. In other words, keeping them full/close to full as well as empty/close to empty is stressful to the cell, and is the main reason behind reduced lifespan.
    That's why these types of batteries are only charged to around 60-70% at the factory, to account for some self- or parasitic discharge prior to reaching the consumer. Never full.
    Ideapad. Try to find the "lenovo vantage" app sa Microsoft store, or maybe you have it already. Sa device settings makikita mo to.
    Is it true sa laptop pag ang charger eh same voltage usually same plug? The charger of my old laptop is giving up. I don't know kung tama charger na bibilhin ko.
    Here is my charger.
    And this is what I'm planning to buy. Same voltage, same amp, and same color of plug.
    https://shopee.ph/product/32525755/1...496?smtt=0.0.9
    Pasok kaya?
    #315
    Here is my charger.
    Pasok kaya?
    they look equivalent naman, electrical numbers-wise.
    Actually yung concern ko eh yung plug. I'm assuming since they are both yellow then they have same size. [emoji23]
    #317
    May mga replacement chargers with multiple plugs if you're worried.
    Hindi lahat ng yellow pareho ng size. Either get a specific charger for your laptop or get one na universal with detachable plugs.
    Thanks, didn't know those exist. [emoji16]
    Jan 2009
    #319
    This reminded me.... Dell laptops can be picky when it comes to using 3rd party AC adapters. If you don't use the correct kind or try to plug in a badly-designed generic power supply, it will flick you the proverbial bird with an "AC adapter unknown" error and it will refuse to boot up.
    But I love Dell laptops (Latitudes in particular) because they're built well and lasts forever.
    #320
    Pasok kaya?
    Not true. Samsung and Asus have the same 19V but different current and different size of crown-plugs. The usual "same accessory should be within the same brand" as the connector and current is model/brand specific, so basing from the pics of the one at Shopee it should fit.
    Dell 19.5V
    msi, Lenovo(slim rectangular connector) 20V
    HP/Compaq 18.5V
    Apple 14.85 magnetic sq connector
    Some are now using USB typeC
Computer and Laptop Tech Thread
