Results 311 to 320 of 954
- Mar 2010
- 2,249
July 26th, 2020 11:12 PM #311The advice in tipidpc is to plug your laptop to ac outlet to prolong the life of the battery, and never let the battery drain below 50% before charging and that includes mobile phones.
July 26th, 2020 11:21 PM #312
Below 30% is my danger zone.
You are aware that rechargeable lithium batteries are most stable at around 50% SoC, don't you? They start to lose life at either end of the scale. In other words, keeping them full/close to full as well as empty/close to empty is stressful to the cell, and is the main reason behind reduced lifespan.
That's why these types of batteries are only charged to around 60-70% at the factory, to account for some self- or parasitic discharge prior to reaching the consumer. Never full.
July 27th, 2020 09:05 AM #313
July 30th, 2020 08:21 PM #314
Is it true sa laptop pag ang charger eh same voltage usually same plug? The charger of my old laptop is giving up. I don't know kung tama charger na bibilhin ko.
Here is my charger.
And this is what I'm planning to buy. Same voltage, same amp, and same color of plug.
https://shopee.ph/product/32525755/1...496?smtt=0.0.9
Pasok kaya?
- 52,523
July 30th, 2020 08:37 PM #315
July 30th, 2020 08:48 PM #316
July 30th, 2020 09:26 PM #317
July 30th, 2020 11:35 PM #318
July 31st, 2020 09:16 AM #319
This reminded me.... Dell laptops can be picky when it comes to using 3rd party AC adapters. If you don't use the correct kind or try to plug in a badly-designed generic power supply, it will flick you the proverbial bird with an "AC adapter unknown" error and it will refuse to boot up.
But I love Dell laptops (Latitudes in particular) because they're built well and lasts forever.
- Nov 2009
- 3,474
July 31st, 2020 09:53 AM #320Not true. Samsung and Asus have the same 19V but different current and different size of crown-plugs. The usual "same accessory should be within the same brand" as the connector and current is model/brand specific, so basing from the pics of the one at Shopee it should fit.
Dell 19.5V
msi, Lenovo(slim rectangular connector) 20V
HP/Compaq 18.5V
Apple 14.85 magnetic sq connector
Some are now using USB typeC
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
