Results 1 to 10 of 88
April 2nd, 2009 08:49 AM #1
Hi folks. I have several questions about surveillance cams and stuff related to them:
1) Are there weatherproof wireless security cams? If there are, do they work via Bluetooth or WiFi? What is the range of their signal?
2) How do they produce the 4-in-1 image on the monitors wherein you see 4 different camera images on each quadrant of the screen? Is it produced by the monitor itself or a separate video device?
3) How many hours/days of video can a regular DVR store?
Trying to set-up a home security system. Thanks.
April 2nd, 2009 09:11 AM #2
There are wireless cameras but they use their own frequency. And wireless security cameras come with their own receivers. So far, I haven't seen a weatherproof wireless cameras though.
April 2nd, 2009 11:29 AM #3
Thanks sir ghosthunter.
Looks like it will be "wired" cameras for us since we plan to install them outdoors, concealed but exposed to the sun and rain.
- Oct 2008
- 944
April 2nd, 2009 12:55 PM #4san po nakakabili ng mga yan and how much po kaya? my friend was asking me this same problem weeks ago, wala lang ako masyado masagot kung san ko siya ipupunta. good thing may nabasa akong ganitong thread dito sa tsikot
pa tulong narin po
April 2nd, 2009 03:36 PM #5
Sa Rover Security Systems sa Gilmore near St Paul's QC. Di ko alam yung pangalan nung building pero dun sa merong Shakey's sa unahan. Sa loob-looban pa nung building yung pwesto nila.
Kung gusto mo makamura, try Raon/Quiapo area.
April 2nd, 2009 04:39 PM #6
isketi, nice thread. Interested rin pang home security system.
Hope you could share pricing and reviews once you get your system na.
April 2nd, 2009 07:01 PM #7
You can start with the DIY shops (like ACE hardware) as a starting point.
But usually I drop by MC home depo at Ortigas Center. There is a store there that sells the whole system. So if you need a whole system or simply a new DVR or camera, its nearly a one stop shop. Prices will vary depending on the stuff you buy. Best to know what you want to use it for (lighting, clarity, etc) before you go shopping for this stuff.
DVRs can be as simply as a stand alone recorder or as complex as a web connected system. A DVR can also be made out of a standard computer.
April 2nd, 2009 07:02 PM #8
April 2nd, 2009 07:05 PM #9
Cameras can differ a lot. Standard video camera will also vary with it's resolution capability.
For best results especially for external locations, use a camera with infra-red emitters. For larger areas which is prone to be dark, you can add extra infra-red emitters to "illuminate" the dark areas in infra-red only if those areas are out of range for the infra-red from the camera.
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
