The power adaptor is optional? ... Supposed to be a PoE line ...
I use Butyl tape to weatherproof outdoor connections.
When wrapped around, it fuses together and form a virtually airtight and watertight seal. Once applied, it will be difficult to remove it if you need to replace or relocate the camera.
https://shopee.ph/NITTO-Self-Fusing-...e-25ffd5f435c0
Butyl rubber tape then cover with vinyl electrical tape.
Mas convenient gamitin yung PoE connector kasi built-in yung weatherproofing cap, just tap the blue and brown wires for the DC input (52V)
Optional ay ung wired lan cable, it comes with a free housing to protect from water. May problem kaya kung naiwan lang na exposed ung lan port?
if you intend to use the wifi connection then you need access to an AC line in order to draw power for the DC power supply (adaptor)
if you intend to use the wired ethernet connector then you have 2 options (POE-ethernet-only or AC-line+ethernet)
for sealing, what was provided is enough. theres an O-ring for the ethernet housing to keep water out. what you need to do is crimp an ethernet cable by inserting first the bare ethernet cable then crimp the ethernet connector
Thank you for your replies. For now I will be sealing the LAN connection with something temporary, maybe I can use the grommet provided. I'll study the PoE line later. As for the power cable, there is a rubber o-ring provided, but I still need one for the extension, so I'll use the butyl tape as recommended here. Thank you.
using old phones as CCTV.. i guess you need to plug it otherwise ma drain battery..
https://www.facebook.com/watch/?v=438110548298332
^downside is as the battery heats up it could overheat the motherboard..too much heat could lead to fire
^pwede naman ata tangalin ang battery at itap na lang ang 6V DC output ng adaptor sa battery terminals ng cellphone para bawas risk ng paginit ng battery thru constant charging..mas tipid pa
ang laki din tulong ng cctv kasi ang dami nabubuking ngayon from percy lapid tapos yung mga pulis na dumukot sa cavite about sa drugs. Wala talaga lusot ngayon unless you wear a deflectior that will blur your face.
pero ang dapat talaga pag pulis ang nasangkot sa kagaguhan eh death penalty by firing squad Kung baga set apart kasi law enforcement dapat hindi patas sa civilian. Ito ang dapat gawin para magdalawang-isip gumawa kalokohan.
again death by head shot, heart, liver.
You can use Macrodroid, IFTTT, and a smartplug to automate charging of the phone battery.
I use that to limit charging of my phone battery overnight to hit 70% only then stop (smartplug turns off the charger). The charger turns on again at 5am to take the phone battery up to 100%, just before I wake up. So I still take my phone off the charger every morning fully-charged.
With the recent firmware update, my S21 now supports Adaptive Charging and Battery Protection. What it does is limit charging to 85% only to preserve battery life. You can leave the charger indefinitely and the battery won't go above 85%.
another case solved dahil may cctv. Yung namatay na babae eh mukhang nirape ng trisikad driver. Like the percy lapid case eh wala din mask. So better na itigil na maskara kasi mas madali makikita fezzz.
Alam mo na ba kung sino ang mastermind sa percy lapid killing kags? Bata ng prisidinti mo.
