Results 1 to 10 of 41
August 21st, 2015 12:03 PM #1
Nag open na ako ng ports sa modem ng PLDT hindi ko pa rin ma-access CCTV ko via internet.
Signature
- 54,281
August 21st, 2015 12:37 PM #2
- Nov 2009
- 3,509
August 21st, 2015 12:47 PM #3Some cctv requires port forwarding with specific port to be opened like a suffix ip: port.
- Nov 2009
- 3,509
August 21st, 2015 12:53 PM #4Btw whats the pldt modem ip, bridge mode static wan, routed/mer, pppoe, dhcp? Port forwarding is useful if you are behind a firewall or another private ip separating the wan.
August 21st, 2015 02:41 PM #5
Plus the CCTV will require a static IP address. Normally it will require a router plug into the modem and configure the router (fort forwarding, static IP address and the open port used).
- 54,281
August 21st, 2015 02:42 PM #6but shouldn't pldt have done all these, making sure it works fine, before they left?
- Nov 2009
- 3,509
August 21st, 2015 03:03 PM #7No, carrier is limited to internet transport only. Cctv is a client app., not unless the cctv is part of the internet package.
August 21st, 2015 04:08 PM #8
maybe you could try to use another router instead. but you have to change the fibr modem to bridge mode.
my fibr modem i have to call pldt for them to make this change. nagtry ako dati palitan nawala lang connection ko. sila lang daw makakapag change remotely.
- Nov 2009
- 3,509
August 21st, 2015 04:40 PM #9There are cctvs that hook to centralized servers na kahit dhcp or behind the router, they should work. I guess these fibr modems are dhcp on both WAN and LAN thats why the cctv couldn't connect. Bridging the router is one solution and its also ideal to have a static ip on WAN to make it more visible over public iP.
August 21st, 2015 04:44 PM #10
naka port forwarding na pero di pa rin ma-access.
parehong naka pldt fibr sa office at bahay. pero parehong hindi ko ma-view cctv sa bahay and office.
i can access the admin config page of the pldt modem. pwede ko bang palitan to bridge mode sa modem lang without informing pldt?
i can access the admin config page of the pldt modem. pwede ko bang palitan to bridge mode sa modem lang without informing pldt?Signature
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
